Question about Amana ARGS7650SS Gas Kitchen Range
This is a gas oven (self cleaning) and the oven part will not heat up. is there a pilot on the oven part of the oven as well as the top part. the top part of the oven will light but the oven won't heat up
  • 432 Answers
There is a electronic igniter.There is on for the bake mode and one for broil.Just do a google search of apliance parts and you will find several places to view the part and some will have parts diagram. Most of the igniters are ceramic and only takes a hair line crack for them to quit working.
Posted on Feb 02, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My GE Profile self cleaning gas Oven JGB908SEK4SS
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
or... The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
    Gas ovens are fitted with at least one safety device and it could be it has failed.
    The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
    Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    My GE Profile self cleaning gas Oven JGB908SEK4SS is not igniting and has a strong gas smell. Is there anyway I can just ignite the oven? Where do I locate pilot light?
    heatman101
    heatman101
    Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    Oven Caught Fire!!
    Remove oven racks and look for two screws in the back on the bottom. Remove screws and lift out oven bottom. Do not use self clean.
    Mar 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Gas oven dosnt work
    the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
    Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    MY HOTPOINT SELF CLEANING STOVE
    how do I get my self cleaning to come on in my hotpoint stove
    May 22, 2008 | Ovens
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Amana ARGS7650SS Gas Kitchen Range Logo
    181 people viewed this question
    Top Amana Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal De
    Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
