Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Temperature is not cold anymore
The fan is running, but Temperature is not that cold. I don't hear the compressor. The Freezer is only about 40 deg.
  • 619 Answers
Your overload relays at the compressor have gone bad. Not hard to repair and worth the fix. Change these and you will be fine.
Posted on Feb 02, 2010
Testimonial: "Absolutely correct. Although this was too difficult for me to change it myself, I had it done for me and its all good now!"
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Compressor clicking on/off - freezer and refrigerator losing cold
I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Maytag fridge not cold
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Mar 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Fridge not cooling down
The most likely cause is a gas leak . Call a technician.
Jan 22, 2008 | Refrigerators
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
591 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
