Question about Bosch Multiplexer
Need the Manaual for a Ultrak KX1600MD 16 Channel
Need the Manual for a Ultrak KX1600MD 16 Channel Multiplexer.
Hxct16e
This is all I can find, might do the trick;
When changing the multiplexer to NTSC or PAL all other settings
are returned to the factory defaults.
The multiplexer can be used with either NTSC or PAL systems.
To set it up for NTSC operation:
1) Turn off the power
2) Press and hold the and {M} buttons.
3) Turn on the power
To set up the multiplexer for PAL operation:
2) Press and hold the and buttons.
Password Code User1 (1111)
User2 (2222)
User3 (3333)
User4 (4444)
Supervisor (5555)
Apr 03, 2014 | Honeywell Hxct16e 16 Channel Color...
Default password
If memory serves me correct, most of the GE/Truvision etc. DVRs have to be sent back in for the password to be defaulted. I may be incorrect on this, will double check.
Jan 01, 2014 | GE Security DVMRe-16CT-600 16-CHANNEL...
My GE Security DVMRe-16CT-1000 16-CHANNEL I power
Sorry this thing it garbage now.The hard drive have bad sectors on the boot up.This can't be repair except replaced the hard drive.Not worth to fix,if have to replaced the hard drive.
Jun 15, 2010 | GE Security DVMRe-16CT-1T 16-CHANNEL Color...
In need of an owners manual
Please download the manual here:
http://www.honeywellvideo.com/documents/9001.0800_Rev101_HEGS5000_5001_UserGuide.pdf
Please rate my solution.
Thanks
MZAS
Jan 03, 2009 | Watches
Manual for ultrak 340 sports timer
Here is a link to pdf maual file. This should help.
www.cei-ultrak.com/sport-stopwatch/pdf/340.pdf
Oct 27, 2008 | Ultrak 100 Lap Memory Professional...
Installer code
Hit menu button, top right of jog, installer code is 3477, then use jog and dial to change settings. These must be done locally!
May 21, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
No Audio
Check in the settings and make sure it is selected to be on.
May 14, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Password
Please find the following passwords.
Ten and Sixteen-Channel Units
Password Type Access Level Function Changeable by user?
Default Password Operator Operator Provides access to the Operator and SystemView menus. Press ‘ENTER’
4 Times
Installer Installer Provides access to all on-screen menus. Password 3 4 7 7
Factory Defaults Installer Resets the multiplexer to the factory defaults (except the time, date, email addresses, and email
IP address). Password 8 1 1 1
Language Installer Provides access to the On-screen
Language menu. Password 5 4 1 5
Ethernet Access Reset Installer Deactivates the ethernet
password, so that the unit may be accessed by any PC equipped with WaveReader. Password 1 1 1 1
Jun 08, 2007 | GE Security DVMRe-16CT-600 16-CHANNEL...
Bosch  Multiplexer  Logo
265 people viewed this question
Top Bosch Computers & Internet Experts
Brett Duxbury
Brett Duxbury
Jerry Z
King
King
Are you a Bosch Computer and Internet Expert? Answer questions, earn points and help others
