Question about Dell Dimension 2400 PC Desktop
WD 5GB nternal EIDE drive is detected by BIOS but not by Win XP.
Dell Inspiron 2400, XP/SP3. New WD5000jbrtl internal EIDE drive attached to motherboard secondary EIDE channel (single drive only). power-up, drive is detected by the BIOS but not by Windows XP. Drive diagnostics run and pass using WD Lifeguard diags.
Note: Multiple drive jumper configuration (Csel, Master, Slave, and no jumper) tested with no XP detection success.
    Scholar:
  • 42 Answers
New drives are not usually formatted, so the drive will not show up in the drive list when My Computer is opened. As this may be the case, the drive will need to be initialize and formatted.
To do this make sure you have administrative rights and locate your My Computer icon which is located in the Start menu or on the desktop. Right click on the My Computer icon then select "Manage" and click on it.
You will be presented with the Computer Management console. Locate and click on "Disk Management" under the Storage part of the management tree.
Many times when this is opened, the system will present you with a wizard to initialize and format the drive. If this is the case then follow the wizard to complete the task.
If this did not happen, look at the list of drives in the list. If the computer recognizes the drive it will appear without at drive letter next to it. If this is the case a right click on the drive with out a letter will allow you to initialize and format the drive.
If the drive does not appear here, then over to the far left in the Computer Management console, find and click on "Device Manager"
Once the device manager is open a tree with all the recognized devices will be displayed. Click on the + sign next to Disk Drives. If the drive is not listed here then the computer does not see it.
If this is the case highlight and click the computer at the top of the Device manager that has the name of your computer. Now right click the computer icon and select the only option witch is "Scan for Change". The computer will look for devices for a moment or two. When complete see if the drive is now listed under Disk Drives in the device tree. If so follow the steps above to initlize the drive and format it in the Disk Management part of the console.
If the drive did not show up, shut the machine down and check the connections to the disk drive.
Also make sure the drive is properly jumped. Most Western Digital Drives have a jumper diagram printed on the label. Set the drive up for single drive or cable select.
After restarting the machine, enter into the BIOS to make sure the machine is in fact seeing the drive. On a Dell Dimension this can be done on restart by pushing the F2 key. This must be done quickly right after start up.
Once in the BIOS use the arrow keys to navigate. Locate the section for hard drives and verify the machine is in fact seeing it. It may be that the secondary IDE channel has been disabled. Make sure it is enabled. Also make sure the drive detection is set to auto if the option is available. Once complete make sure to save changes to the BIOS. When complete the system will be restarted. Allow the system to boot Windows. It may recognize the device now and prompt with the wizard.
If not use the steps above to check the Disk Management under the Computer Management console to see if it is there.
If the drive is still not there try testing it in a different machine or seek professional services to rectify the issue.
Posted on Feb 03, 2010
  • Dell Master
  • 12,061 Answers
It should be on Primary channel if it is the only drive... with the jumper on master. No other way will work.
If windows won't see it then it may be unusable OR need a reformat & re-partition.
Posted on Feb 02, 2010
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Is there a inbuilt bluetooth in dell ins. 1012? if yes then i am unable to detect it, i am using win xp sp3...plz help me
Yes, your computer is supposed to have bluetooth, but you first have to install drivers for it. On this site you'll find these drivers and installation instructions.
If my answer was helpful, please rate it :)
Sep 06, 2011 | Dell Inspiron Mini 1012 Netbook...
Bought new hard drive for mini 1012 dell bios sees new hard drive but when i try to install windows xp , xp says no mass storage device detected.
In the bios change the drive options to anything but AHCI if possible. You will need a windows xp driver and USB floppy disk to install the AHCI or SSD driver. It's also referred to as an F6 Floppy. Dell should have the download you need.
Jul 18, 2011 | Dell Inspiron Mini 1012 Netbook...
Will pata hard drive work on dell inspiron 600m? WD Scorpio Blue 160gb PATA drive
Yes, the Dell inspiron 600m uses the EIDE/PATA interface so your new drive should work fine.
Oct 04, 2009 | Computers & Internet
I have a dell inspiron 1525 model..............yesterday i connect it to a net to find the keygen of some software so i turn off my antivirus so viruses were come and c drive gets badly harmed ,,,,,,,,now...
First thing you needs to install new windows via boot able CD.
Please do not start installing windows while running ur old windows. i mean please not upgrade ur windows to newer once.
Steps for installing fresh windows :
1. Make bootable win xp disk.
2. Insert Disk into drive and boot ur laptop with CD drive (If unable to boot then change BIOS settings)
3.Setup will automatically detect ur previous version of Windows.Just ignore it and start fresh installation and alll Done.
May 16, 2009 | Dell Inspiron 1525 Laptop Jet Black
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Dell Dimension 2400 PC Desktop Logo
130 people viewed this question
Alun Cox
