Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
My keys on my keyboard have a mind of their own. The ? turns into a French E and my @ can't be found anywhere! How can I fix this as it drives me crazy?
Keyboard is in french need to change to english
Press Ctrl+Shift at the same time. Toggles the French (blue) keys on & off. I found out after much tedious searching. Hope this helps you!
Nov 25, 2010 | Computers & Internet
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Feb 12, 2010 | Acer Aspire 4530-5889 Notebook PC
I cannot get apostrophes or question marks. Instead I get French accented letters. Can you help me
Nov 14, 2009 | Compaq Keyboard
How to make french accents marks on a laptop that doesn't have a number pad
You need to tell windows it has a french keyboard:
In the control panel, go to regional and language options.
Go to the keyboards and languages tab, click change keyboards. On the window that pops up, click on the general tab. You probably have just the us keyboard installed. Click add, then choose either english-canada or french-france, then click to add the french keyboard. Click preview to see where the accent keys will be (so you can find them). Now, select the french keyboard and click 'move up' so the french keyboard is above the us english one.
Voila!
Hope this helps. Post a comment if you get stuck.
Joe
Oct 13, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
My Key board types in french, how do i turn it back
Aug 13, 2009 | Computers & Internet
Question mark key always comes up as a french letter e -
I use 2 different keyboard types too.
Have you tried pressing [Ctrl]+[Shift] to change the keyboard type you are in. Even if you choose a default language in a program all other program will still use the other keyboard type, hope this helps.
Aug 04, 2009 | Computers & Internet
Keyboard will not respond on zv5000
one problem I have with mine is that the keys need to "warm up" after you first start up the computer. This usually takes anywhere from 15-20 minutes to do.
This may be why your keyboard does not respond.
The simple fix I found was to just connect a separate keyboard via USB.
Sep 28, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computer is locked in the green symbols of the keyboard
TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
Click CONTROL PANEL
click CLOCK, LANGUAGE, AND REGION
under REGION AND LANGUAGE
click CHANGE KEYBOARDS... etc.
click KEYBOARDS AND LANGUAGES
.......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
click APPLY
click OK
Then you've removed the French.
Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
Jan 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
Functon Key Hit in Error -- Which One
You turned on Verr. Maj. by hitting [ctrl] [shift]. Hit it again once or twice to turn it off. Normal = ?, then [ctrl] [shift] =
Jun 19, 2007 | Logitech MX 3000 Keyboard and Mouse
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
76 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
