Question about Panasonic Audio Players & Recorders
F61 code error on a Panasonic sa-ak78 - Panasonic Audio Players & Recorders
5 Suggested Answers
zair
  • 82 Answers
SOURCE: F-61 error,dead panasonic model#sa-ak78
Have you changed the Regulator IC? Also check the IC protector next to regulator, it looks like a fusable resistor.
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
SOURCE: F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Posted on Sep 06, 2009
pjbaldi
  • 8 Answers
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
Posted on Feb 26, 2010
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
F61 ON SA-AK78
You may have the same problem as I had..broken solder joints on power amp board..namely the power relay.
Nov 08, 2011 | Panasonic SC-AK78 CD Shelf System
Hello i have a panasonic SA-AK78 and show F61 and don't turnd on.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 13, 2011 | Panasonic SC-AK78 CD Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 Panasonic SA-AK240
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti ajuta??veri.nice78@yahoo.com astept un raspuns
Sep 08, 2010 | Audio Players & Recorders
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Trouble
I had to replace the fan on my unit. Now it works like new.
Dec 31, 2007 | Panasonic SC-AK78 CD Shelf System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
409 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
