Question about Vehicle Parts & Accessories
1999 Ford f150 aftermarket ignition disabler problems
I have a 1999 Ford f150 with a aftermarket ignition disabler under the dash. I have to push a key into the blinking receptacle before my engine will start. I want to remove this system from my truck so I can start the truck in the standard way. The key says ''Enforcer'' on it but that is all the info. I have on the product. How can I remove or disable this product? Thanks
    New Friend:
  • 71 Answers
Sounds like a good theft proof system. I would trace all the wires and see where they go befor removing anything see if the thing disable breaks a circut when you turn it on it complets a circut. thats what i would be looking for.
Posted on Feb 02, 2010
I just changed engine in a 97 ford f150 5.4 now it wont start everything is pluged in allsensors are good whats the problem?
Check the fuses in the fuse box under the dash and theignition fuses under the hood one might have blown I would start with the ones under the dash I had this problem before. If the engine ran before then the computer boxes and control modules must be good you have I believe two ignition fuses one. Under the hood and the other under the dash. Hope this helpd
Dec 31, 2014 | Ford Cars & Trucks
Dash light on key off f150 ford
most likely is ignition switch. it is adjustable. under the dash on the steering column there are two bolts that holt a square box onto the column. that is the ignition switch. may need to be slid down towrds the pedals. can be aggravating trying to fine adjust it. if that doesnt work, replace it. about 25$
Apr 16, 2013 | 1990 Ford F150
I purchased a battery to a 1999 plymouth voyager sport. When I put the battery in the horn start blowing. I tried starting up the van it wouldnt start. What could be the problem? The windshield wipers...
TRY RESETTING IMMOBILIZER BY PUTTING THE IGNITION KEY IN THE IGNITION SWITCH.TURN KEY TO THE ON POSITION WITH ENGINE OFF UNTIL IMMOBILIZER WARNING LAMP ILLUMINATES FOR 3 SECONDS.THEN TURN OFF THE SWITCH THEN TRY TO START THE ENGINE.IF IMMOBILIZER IS OKAY.CHECK FOR A BLOWED 40 AMP STARTER FUSE OR YOU HAVE FAULTY STARTER RELAY.
Apr 30, 2011 | 1999 Plymouth Voyager
Problem with starting 89 F150 straight drive. Ignition or clutch?
Sit up on the clutch paddle, follow the clutch paddle up under the dash, the rod that goes through the fire wall to the clutch master cylinder, sit around that rod, will have a six pin connector going to it.
Dec 26, 2009 | 1989 Ford F 150
How do i adjust an ignition switch on a ford f150?????
lossen up the two screws on the switch ,on the steering columturn the tumbler to acc , push or pull the switch accordingly then tighten the screws, thats it your done!!
Aug 31, 2009 | 1991 Ford F150
Location of the fuel pump relay switch 1985 Ford F150
Its under the hood drivers side on the upper firewall.
Apr 13, 2009 | 1985 Ford F150
4W will not turn on ford ranger 1999 4x4
that clicking sound you no longer hear is a relay switch behind dashboard ....aftermarket one's sold at all chain auto parts stores
Nov 21, 2008 | 1997 Ford F150 Regular Cab
Relay
there should be a couple inside the fuse box inside the truck under dash, the rest are under hood in the power distribution box, hope this helps, let me know
Oct 04, 2008 | 1999 Ford F150 Regular Cab
Vehicle Parts & Accessories Logo
241 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
