Question about Lexmark X4270 All-In-One InkJet Printer
Hi:My print spooler is off.How can I get it on?
    Novelist:
  • 157 Answers
You can turn on the print spooler via the control panel.
Open the control panel, go to the administrative tools folder, then select services (open the program), scroll down the right side list of services till you find "print spooler". Highlight it and then on the left top, select the start option. The spooler should then start. There is a status value next the the print spooler name. Check it before you attempt to start it. It should show stopped. If it is started, try restarting the spooler, it may correct your problem also.
Good Luck.
Posted on Feb 02, 2010
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Print spooler not working
Hi Good day!!! Maybe your print spooler stop, check your printer spooler in your control panel "Start - Control panel - Performance and maintenance - Administrative tools -Services - check your print spooler in the services box. or simply restart it. and then restart your computer. your printer spooler should running now.
Don't forget to vote thanks!!!!
Nov 02, 2010 | HP Office Equipment & Supplies
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Scan problems
Hi there
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X5650 All-in-One InkJet Printer
Print spooler problem cannot delete printer jobs
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | Office Equipment & Supplies
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Jan 08, 2008 | Dell A920 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
