Question about Pantone ColorVision Spyder2 monitor calibrator (GEU110) for PC, Mac
I inserted my Color Plus CD to calibrate a new monitor on my new Dell XPS Windows Vista system. It does not even aknowledge that there is a disk in the drive. I bought the Color Plus program back in 2005 and it worked perfectly With Windows XP.
  • 10,865 Answers
Hello. The problem you are experiencing is due to the fact that your driver [disk] is for Windows XP and you now have Windows Vista. NO real problem though since you can download the driver you need for free off of the internet. Here is the link: http://support.dell.com/support/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn&~ck=mn
Just locate the driver you need then download and run.
Posted on Feb 02, 2010
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
My sound stopped working. How can i check to see if my sound card went bad.
Go to www.support.dell.com andselect "I'm looking for drivers and downloads". If you don't have theproper version of Adobe you will be prompted to install it. Once installedreturn to "drivers and downloads" and enter the "servicetag"(serial number) of the laptop.
You will need boot from this CD so that you are not loading your Operating System software (i.e. Windows XP or Vista).
To boot from a CD disk, power on your computer and tap the key to bringyou to the "One time boot menu". Insert the CD into the top CD/DVD drive andthen select "Boot from CD/DVD" and hit key. Select the "Runthe 32 Bit Dell Diagnostics.
If all tests pass then reload OS ( Operating Software ).
Jun 10, 2011 | Dell Inspiron XPS M140 Notebook
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
Dvd stuck inside slot drive, system had crashed
hello..to get out you`re CD/DVD its very simple you need a small Pin like a paper clip then find the small hole the front side of DVD/CD player and push the hole using the paper clip..about this question kindly Verify>(plus i had already installed the new hard disk because the old one crashed)..what is it??...Thank you
May 08, 2009 | Dell XPS M1330 Notebook
Trying to install Lexmark X5130 onto Laptop
I have a Lexmark 1100 series printer that works with my Dell XPS M1530. So it is possible. I found this driver, http://www.xpvistasite.com/lexmark_x5130_8613.htm.
I never mess with the printer cd. I just pluged it in and vista found a driver for it. I only use the printer and the scanner.
Jan 14, 2009 | Lexmark X5150 All-In-One InkJet Printer
Dell E173FP monitor on Visa
HI,
Are you putting in the Dell color monitor Cd to install the monitor ?
The new computer should not require,any drivers as its plug and play
Thanks
Proton
Jul 27, 2008 | Dell E173FP 17" LCD Monitor
Monitor configuration
Did you also install the LG software and LG Drivers correctly?
With my LG flatron i received a piece of software to optimize my settings and even calibrate the monitor. I run win XP ME.
Jul 04, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Contents of CD-ROM not displaying
actually some new laptops dont identify these pirated cd types so you try and update ur vista from microsoft and see if any update for your rom driver is available!!otherwise contact your laptop vendor!!
Jan 31, 2008 | Microsoft Windows Vista Ultimate Edition
Pantone ColorVision Spyder2 monitor calibrator (GEU110) for PC, Mac Logo
88 people viewed this question
Top Pantone Computers & Internet Experts
David Payne
David Payne
Are you a Pantone Computer and Internet Expert? Answer questions, earn points and help others
