Question about Maytag MDE9700AYM Electric Dryer
There is power but it doesn't turn on - Maytag MDE9700AYM Electric Dryer
  • 254 Answers
Check the themal fuse on the backside of unit usually blows beccause of venting issues this is the cheapest repair or problem.... maybe try to reset it possibly by unluggin or killing power at breaker for a few minutes... if still a probelm might need service it posibly could be a control board or user interface problem kinda common for those to blow after power ooutages and also because its electronics.. hope this helps
Posted on Feb 02, 2010
My stagg amplifier doesn't power on anymore, just
Internal power transformer or rectifiers. Could also be main power transistors.
Apr 20, 2012 | Audio Players & Recorders
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
Have a late 2007 macbook pro and it doesn't turn on..tried the pram smc and it still doesn't turn on is there any other way to fix the problem>?
Unplug the power cable; remove the battery then hold down the power button for 30 seconds. Reinstall the battery; plug the power back in and hold down the power button for 30 to 60 seconds and see if it starts.
Aug 01, 2011 | Computers & Internet
Power lights flashing,will not stop
Ok sir try to turn off the printer if it doesn't. Pull the power cable shutdown your computer then plugged again the power cable of the printer then turn on the pc and printer..If it doesn't change contact a printer technician or bring the printer to the nearest service center. Hope it helps you..
Jul 01, 2011 | HP Office Equipment & Supplies
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Sylvania Netbook SYNE T07526-Serial #7128230710064387. Bought less than a year. Stopped turning on.
When you said it's not turning does it have any indication of power and just doesn't boot to your operating system or It doesn't have any sign of power at all?
If it doesn't have power, try to remove the battery plug it into the power outlet using the ac adapter and turn it on. Check the adapter to see if it has a light to make sure that the computer is receiving power.
If the computer turns on but you can't get to windows see if any error message is displayed and be ready with your windows cd/dvd because a reinstallation might be needed.
May 23, 2011 | Sylvania G-Netbook
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Designjet 110 plus not turn on
do you change formater board ?or try use firmware utilit you can find it here
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Sep 22, 2008 | HP Designjet 110plus nr InkJet Printer
My Sansa doesn´t work well,
If it is still on, hold down the power button for about 15 seconds; that should turn it off. Try turning it on again. If it still does not work, turn it off by holding power for 15 seconds, then on again like this: - Put hold on - Hold record - Press power on This will start recovery mode, follow on-screen instructions. Hope all goes well!!
Apr 29, 2007 | SanDisk Sansa e250 MP3 Player
Maytag MDE9700AYM Electric Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
