Question about Microsoft Windows 2000 Professional for PC
How to configure a dual boot system using windows 2000 and windows 98??
  • 29 Answers
First split the harddrive into two partitions. Install Windows 98 first. Put it on the first partions. Then install Win 2k on the second partition. If you attempt to install sin 2k first you will be unable to install win 98
Posted on Feb 02, 2010
Aspire 5720 Hard Disk Configuration Error
try this site it is very helpful however you need to use other computer since your HDD is not anymore detected by your system...
http://en.kioskea.net/faq/2040-acer-pc-restore-to-factory-settings
Mar 28, 2010 | Acer Aspire 5720 Notebook
Tip
How to make dual boot with window xp vista and windows 7
Dual booting Windows is the most challenging of the three options; however, making it work can be very rewarding. The process of creating a dual boot environment differs from Windows Vista to XP. Please follow the instructions according to which version of Windows you are currently using.
To run two operating systems on your computer, you will need to add a second partition. If you are not familiar with adding a partition, you can learn how in this section. Please note: each operating system will be able to see the other partition; thus, you can share files between them.
Dual Boot with window x and windows 7
You will need third party software to create a second partition for Windows 7; once you have created the partition, you can install Windows 7 on it.
Create a New Partition (Vista)
Click the Start button, right click Computer, and clickManage
In the left pane, click Disk Management
Now create a new partition by shrinking a previous volume so you can use the newly created space. Right click on the partition and clickShrink Volume.
Now right click the free space and click New Simple Volume…
Specify the volume size and click Next
Format the drive as NTFS, give it a label, and click Next
Power on your computer, insert the Windows 7 DVD, and restart your computer
Press the necessary key to initiate booting from your DVD (usually Esc or F12.)
Windows will now load the installation files.
Click Install now
Your computer will restart several times during the process as it configures itself and installs updates Be sure to leave the DVD in the drive and let Windows take care of itself.
Memory (RAM) – 1.25 GB required, 2 GB memory recommended.
Recommended 15 GB hard disk space per virtual Windows environment.
NB: Windows XP Mode is only available in Windows 7 Enterprise, Windows 7 Professional, and Windows 7 Ultimate.
on May 11, 2010 | Computers & Internet
Tip
How to remove Multiboot Option in Windows
If under various circumstances you had to install a second Windows OS on the same system, you should have already met the dual boot option. It will pop up before booting the system permitting the user to select which OS will boot.
Boot.ini, the house of the dual boot option Boot.ini is a system file found in the system root. Because it has a major importance for the booting process.so we have to edit this boot.ini file to remove multiboot popups.
How to edit Boot.ini
1.Go to Start Click on Run
2.Type msconfig.
Once the system configuration window pops up, you will notice that Boot.ini has its own tab. Select that tab and where you see "timeout," set it to a lower or higher value. Remove/Add Operating Systems in the dual boot menuThis is the main issue.
Step 1:Right click on My Computer icon and select Properties.
Step 2:From the properties window go to Advanced > Startup and Recovery > Settings.
Here, you can both edit the timeout value and modify the Boot.ini file by clicking Edit. If you remove the second operating system from Boot.ini, the dual boot option won't appear before booting.
For more details information visit How to Remove Multiboot Option in Windows XP
on Jan 08, 2010 | Computers & Internet
I need to setup a dual boot computer. I have 2 hard drives each has an os I need the option to select at startup
Try Install KDE on your desktop, I think its much better than gnome for booting setup. There's another way which one you'd like to booth by striking the F8 key repeatedly on the restart or starting your PC and select the drive which drive you like to boot.Or you can configure it on your bios setup by hitting the del key and configure your boot priority.
Sep 11, 2009 | Microsoft Windows XP Home Edition
It possible to run 2 differant os on 2 differant hd on 1 compute
to be honest, im not sure if its possible....you can only do it using dual boot but it only uses a single hardisk with 2 separate operating system.
how to make a dual boot can be found here
supported dual boot configurations here
if you need more information, please let us know
Feb 07, 2009 | Maxtor DiamondMax® 6800 10 GB ATA-66 Hard...
Boot loader problem
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
Oct 31, 2008 | Microsoft Windows XP Home Edition
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
Install window xp over vista ultimate
CHECK WITH YOUR SYSTEM MANUFACTURER WHETHER OR NOT YOUR WARRANTY IS VOIDED IF YOU INSTALL AND DUAL BOOT WITH WINDOWS XP. MANY OF THE NEWER SYSTEMS ARE DESIGNED AND CONFIGURED TO ONLY RUN WINDOWS VISTA. HARDWARE ON YOUR SYSTEM MAY NOT BE DESIGNED TO RUN WINDOWS XP.
Here is how:
http://www.pronetworks.org/forum/about88231.html
Jan 01, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows 2000 Professional for PC Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
