Question about Refrigerators
I have a Whirlpool refrigerator, Model # ET18NKXFW0 1, Serial # EG5130791. It has working fine for 12 yrs. I recently moved it from one location to another in the back of a pickup on its side. As soon as it was back up right for 24 hrs I plugged it in. Thought it was running fine then in about 12 hrs it blew a gfi circuit breaker on the outlet. So I tried another outlet and it did it again. I moved it to another place in the house, different outlet. It ran almost another 23 hrs and it blew again. When first plugged in it still gets cold, had the temp control adjusted accuratly. We throughly cleaned everything inside and out, around plugs, underneath, checked wires? Why does it keep blowing the gfi circuit? Please help Thanks, Cynthia
  • 619 Answers
Refrigerators should never be plugged into a GFI due to the start up amps that it draws on start up. With other items on the same circuit it is too much of a load. Refrigerator need to be on there own individual circuit to keep this from happening and not a GFI. Hope this helped.
Posted on Feb 02, 2010
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool eet171pk relay switch
do you mean the compressor won't start and you hear a clicking sound every few minutes?if so most likely the start device on the compressor is bad,you have to send the model number off of the machine,if it's a bottom mount or side by side,open the fridge door and look on the right side wall up near cieling and you'll see a tag with model and serial numbers,if the freezer is a top mount open the fridge door and look on the left side wall up near cieling and send model number so someone can look up your machine.have you vacuumed out the coil,if the coil is filled with dust the machine will run hotter than normal and can damage the start device and the compressor.
Sep 30, 2017 | Whirlpool Refrigerators
Ice sheet on back of ice maker & in ice bucket
Happy 20th Birthday Refrigerator. Time to replace.
Jun 25, 2017 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We recently ''inherited'' a Whirlpool MARK I series Side-by-side refrigerator with a house we purchased, Model #EED221MKWR0, and would like to know how old it is, and how efficient (or inefficient) it is....
Any frig that is working is worth keeping as a secondary storage source. The serial number can be used t determine the manufacture date and location.
Eric
Nov 24, 2009 | Refrigerators
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Looking for refrigerator use and care guide for mod.ed2vhextbo1 ser.hrt4930458 and info about changing filter and type of filter
i do not think that is a good model serial number. at least not the format that whirlpool has used in several years or in the u.s.a.
the model serial numbers should be on a tag easily located with out moving unit.
unless this is a vendared product with a Whirlpool name on it (usually a dorm frig or the like)
May 15, 2008 | Whirlpool Refrigerators
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
