Question about Zenith Z56DC1D 56" Television
Need to replace the lamp but dont now where to buy it
  • Zenith Master
  • 8,457 Answers
Tries Partstore.com,Ebay.com for the lamps.
Posted on Feb 02, 2010
Why won't Reverse lights work no matter what I do?
Find and check the reversing lamp switch, it may be on the gear linkage or on the side of the gearbox/transmission.
you should a 12volt feed whenever the ignition is turned on. If you dont, recheck all fuses with a test lamp ( which you can buy from any auto parts store) and check the wiring for an open circuit or break in the wire. If power is available, check the output of the switch by testing each wire in turn with the ignition on and the gear shift in reverse ( dont have the engine running for this).
If you cannot find an output, replace the switch. If you find an output, check the wiring all the way back to the reversing lamps with the test lamp by carefully stabbing the correct wire until the test lamp no longer lights up. this means the break is bwtween where the tested the wire and it lit up and where it did not light up.
Repair or replace as needed.
May 20, 2014 | 2004 Chrysler Town & Country
I have a mitsubishi WD- 6oc9 tv when i power my TV i get a steady blinking light and no picture. my husband replaced the lamp about six months ago. dont think thats the issue. need ideas on how to repair.
Sounds like lamp needs replaced. If you purchased a cheap lamp from ebay or your installer did, that is about all they will last. On your next lamp buy an osram or Philips lamp. They are a lot better quality.
Feb 05, 2014 | Mitsubishi Televison & Video
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
I turn on the tv and it turns on and off and the tv dont show a picture
Your lamp has burned out on the back of the set left or right side there is a door with 3-4 screws un-screw and pull out lamp tray. Buy lamp online or local and replace.
Oct 24, 2010 | RCA HD52W58 52" TV
I have a toshiba and i need a lamp bulb but dont know what sides i have a number off the tv
Tries websites like Ebay.com,Partstore.com just follow ur tv brand and model #... than buy the projection lamp for the replacement.U have the tv brand and the model #...the projection lamp will fit ur tv,because they come in standard sizes for it.
Apr 30, 2010 | Toshiba 50HM66 52" Television
Sony 42'' kdf42we655 no picture , lamp light flashing
If the lamp light is flashing, yes you need a new lamp. Be sure to buy an original Sony lamp as the replacement lamps are garbage and are not worth the discount. Please rate this solution. Thanks!
Nov 15, 2008 | Sony KDF-42WE655 Television
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Replacement Lamp
If your model is the D52W19 you dont have a lamp you have three CRTs ( picture tubes) instead. What is the symptom? I have a good source for RCA parts. Please respond to this same post and if D52W19 isnt your correct model number please post that as well and I will assist you with your set.
Aug 04, 2008 | RCA D52W19 52" Rear Projection Television
Power supply
Almost, but i would recomend getting the training manual for your set so you dont buy a power supply needlessly as the training manual has step by step proceedures for your Chassis to diagnose whats wrong. You need the ATC311 training manual. They will email it to you at the following link.
http://servicemanuals.vstore.ca/
May 06, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Zenith Z56DC1D 56" Television Logo
90 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
