Question about Stanley Bostitch F21PL Nailer
The contact head came half way out. When I turned the gun up side down, it fell up into the body of the gun. HELP!!
    Problem Solver:
Sounds like the plunger has broken, four allen head screws on top of gun remove and pay attention to each part and how it comes out. not hard to replace if you want to attempt it. just lay the parts out in the order removed and clean and oil then put back in reverse order.
Posted on Feb 02, 2010
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
I have a N59 FN air is leaking from the bottom of gun I put ne trigger and O rings still leaking now what.
Air leaking from the bottom of the gun (path of driver) indicates that cylinder seal orings are leaking (if without nails in gun the driver is slowly pushed down the cylinder when air is connected then cylinder seal is leaking ). Cylinder seal snaps on the top of the cylinder and should fit snug and have no cracks. Easy fix for cylinder ring. Remove head and pull out cylinder. Then remove the cylinder ring (part #n50015). Examine ring for cracks and replace as needed. Examine body of gun where spacer oring makes contact and sand fine scratches. Replace orings as needed. If air is leaking between body of the gun and nose casting, replace gaskets. Good luck.
Jun 25, 2012 | Stanley Bostitch Nail Gun
Air leaks thru exaust on Hitachi NV 83 nail gun I have replaced exaust valve and several o rings to no avail.
Examine exhaust tube under valve for cracks and make sure that the tube seals correctly against body of the gun with rubber gasket. If tube is ok and has rubber gasket in place, check for correct cylinder movement. Press down cylinder with thumbs, the cylinder should return. If it stays down, pull it back up. If it is very hard to pull up, cylinder orings too tight or body of gun is warped. If it comes up with light to firm pull, go ahead and reinstall the head and test. If air leaks, try bumping the head of the gun (with air connected) against firm rubber to reset the cylinder against headvalve. If it still leaks, suspect that the cylinder is not moving up against the headvalve due to tight fit. Remove the cylinder and sand surfaces where orings contact to remove fine scratches with 400 grit paper. Also stretch the spring below the cylinder a bit to exert more pressue. Lube the cylinder with silicone paste lube. If you suspect warped body, remove all the orings from middle section the gun and insert the cylinder into body looking for out of round (with no orings the cylinder should just slide in to body of gun easily). Good luck
Sep 24, 2011 | Hitachi Tools & Hardware - Others
Just replaced o rings and piston bumper, but gun still leaks air (out of nozzle) and wont fire at all
Air leaking thru nozzle (where nail exits ) can be caused by two issues. Air leaking past valve rubber at top of cylinder where headvalve seals when under pressure. If leaking at valve rubber seal the piston will usually be pushed down if there are no nails in gun. If the driver stays up while leaking then problem is at cylinder plate. This plate has two orings that seal air pressure. On seals against the body of gun and the other seals against cylinder. Leaks can occur if body of gun is worn, warped or has scratches where oring makes contact. Also look closely at the plate for crackes. Replace parts as needed. Good luck
Feb 27, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Fireing pin moves very slow, it seems to have no power. It comes out slow, I have to push it back inside the gun. It was leaking out the back so I adjusted the cyclinder and now the piston moves too slow...
When you trip the safety and fire the gun, the cylinder drops down into body of gun allowing a rush of air to push piston down with force. If the cylinder fits too tightly in body, it will not open enough to allow full air pressure into cylinder. Remove head and check that the cylinder moves rather easily down then back up (it should travel about 1/4 inch). If is difficult to move the cylinder then remove it and replace all the orings that contact its surface. Also make sure that the outer part of the cylinder is smooth where orings contact. If there are fine scratches, remove them with 400 grit sandpaper. Lube cylinder/orings with silicone paste lube. While cylinder is removed check that lower bumper is in good shape with no missing pieces. For best performance, also replace the three orings on the feed piston. Piston /driver should move down cylinder with only slight pressure yet it should not drop down the cylinder under its own weight. Good luck
Jan 16, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
I pressed the shutter release button while attaching the lens to the body. Now my Hasselblad is jammed. The diaphram is closed, the shutter crank knob is turned about halfway, and the lens is stuck half...
On my Hasselblad 501 CM, I have never encountered this problem. As expensive as these cameras are, and delicate, I wouldn't chance it. I would contact the Hasselbad company and ask them to fix it for you.
http://www.hasselbladusa.com/service--support/technical-support/contact.aspx
I would try the above link to contact hasselblad's tech support if I were you.
Good luck on this.
Dec 25, 2010 | Hasselblad 501CM Medium Format Camera
Airblowing out bottom of nailer thanks for your help
Air blowing out bottom of nailer indicates problem with cylinder seal and/or cylinder spacer orings. Remove head and check seal at cylinder; if seal is broken or loose, replace with new. If seal is good, pull cylinder and check oring that contacts body of gun and oring between cylinder and spacer. Make sure body of gun is not scratched (sand with 400 grit paper if necessary). Parts are at www.toolpartsdirect.com. Good holidays
Dec 10, 2010 | Stanley Bostitch Coil Framing Nailer
T250S-F16 16 Gauge Straight Finish Air Nailer i have an air leak out of the front of the gun where the driver comes out and makes contact with the nail head (the hole tri-shapped hole) It only leaks after...
Air leaks from the bottom of nailers are due to leaking oring /s that seal cylinder to body of gun and/or leaking thru seal at top of cylinder where headvalve seats. Remove head and examine sealing surfaces of headvalve and top of cylinder. Must be smooth, then pull out cylinder and check oring/s that contact body of gun. Remove any fine scratches on inner body with fine paper (400 grit). Lube with silicone paste. Good Luck!
Sep 26, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Paslode 900420 piece fell out
Be sure to remove the metal nose piece that covers the lockout bar when assembled. It may be stuck to the other half of the gun. Replace the bar and the spring and put the metal nose piece in its position over the lockout bar. At this point the metal nose piece will be on the opposite side. This will allow you to replace the 2 halves carefully so as not to loose the spring.
Apr 23, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Stanley Bostitch F21PL Nailer Logo
90 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
