Question about Fargo DTC525 ID Card Printer
My fargo 525 id card printer all of a sudden does not recognize the presence of a ribbon. the display reads "ERROR: no ribbon installed". what is up with that?!
  • 526 Answers
Hi Goodan,
Most likely the upper ribbon sensor has failed and needs to be replaced.
It senses the white lines between each color.
One thing you might want to try, is to calibrate the ribbon in the printer drivers.
thanks adi
Posted on Feb 02, 2010
I have ribbon and am using photoshop,how do i print uv with hdp5000?
To print with UV on a Fargo HDP5000 printer you first need to get a UV color ribbon: YMCFK. The part number is 84061.
After you have your UV ribbon installed you will have to load your cards and tell the printer where you want that special UV logo/design to go. The easiest way to do this is by using Asure ID Solo 7 software. This design software is made by Fargo and has a check mark box on the top where you can either turn the UV design on or turn it off depending on how you plan to create your card. Asure ID Solo 7 costs about $150 but it's very easy to use and makes the print process easier.
There is a second option which involves not using Asure ID and instead creating your UV design through Fargo's "Work Becnch". This process of creating UV designs through work bench is slow and not the most efficient but it is free.
Sep 28, 2011 | Fargo HDP5000 Thermal Printer
Which tipe of ribbon to be used in DTC525
hello
http://www.idsuperstore.com/fargo-printer-ribbons-fargo-dtc525lc-ribbons-c-5_79_1472.html
try this link for your ribbon printers
thanks
Mar 03, 2011 | Fargo DTC525 ID Card Printer
Idon't have a driver
Look in the drivers support free sites available in the Fargo official site.
Sep 15, 2010 | Fargo DTC525 ID Card Printer
Persona C25 Thermal Printer: I have a Fargo DTC520 that suddenly shows ERROR NO...
Without looking at it, I would have to say the ribbon sensor needs replacing. We do repairs if your interested, located in CA.
May 14, 2010 | Fargo Persona C25 Thermal Printer
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
My printer displays ribbon error. but there is ribbon inside
you can change which ribbon type is installed in the printing preferences of the printer driver.
make sure you have the right ribbon type selected.
CYMTKO vs. CYMTO, etc.
There is also a button that will auto detect the ribbon right underneath the pulldown menu.
May 26, 2009 | Fargo DTC550 Thermal Card Printer
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Problem on card print using Fargo DTC525 Single Side Print model
you can check with fargo, or perhaps your vendor is giving you the bad rep, since they refuse to help you. i would not do business with them again.
if the printer worked before maybe the program needs to be reinstalled.
Jun 10, 2008 | Fargo DTC525 ID Card Printer
Fargo c16 card printer
it is time to upgrade your printer
Mar 06, 2008 | Fargo Persona C16 Thermal Printer
Fargo DTC550
My printer is Fargo DTC550 and I'm using HID 1326 card for printing. I cannot get this equipment to function correctly. I had no
problems installing the software and hooking up the printer to make the ID
cards, but all attempts to print an ID card have failed. Every card I have
tried to make has been unsatisfactory, with colours not printing, very poor
image quality, and the lamination device consistently jamming for every
single card I have tried to make.
Sir, please help me.
Showkat
Nov 26, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC525 ID Card Printer Logo
47 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
