Question about Brother FAX-575 Plain Paper Thermal
My ribbon is caught, looks like it's misfeeding a bit. How shall I repair it? Thanks, Vicki
  • monpura4 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 02, 2010
How can i lower the mattress on me sorelle vicki crib? when i bought it it was already assembled and the matress was on the highest level now my baby can sit up so i want to lower it so she will not be...
Here is what I think is your owners manual. Try it and respond if it doesnt help. Good luck, looks easy.
Looks like 4 bolts that have wingnuts are removed and the mattress support brackets can be swiveled lower and the holes on the mattress support further in are used with the bolt/wingnut combo. This lowers
the mattress support.
http://www.sorellefurniture.com/newinstructions/VICKI%20BRU%20CRIB.pdf
Mar 08, 2011 | Sorelle Vicki
Changed the typewriter ribbon because it snapped in two. At first the typewriter would not do anything and was beeping and the "store", 1 1/2 and 3 lights were on. I oiled the carriage as...
do you have a printwheel in this machine (round grey disk with "fingers" evenly spaced around it with the charachters on it)? If not - there's your problem. you can repair the ribbon with a small piece of tape (no wider than the ribbon. stuck to the backside (shiny) of the ribbon then turn the ribbon until the taped part goes into the cartridge a ways. if the ribbon is moving ok and you still have a printwheel installed, make sure the ribbon is not getting caught in the printwheel.
Dec 20, 2010 | Nakajima AX-150 Typewriter
My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Dec 07, 2010 | Printronix Line Matrix P5005B Printer
Hi I have an LG Fuzzy Logic 8.5k top loader. I am looking for a manual for it. It won't drain the water - an alarm goes off and the drainage error lights up. Thanks Vicki
Check in the drain pump for debris. Behind access panel lower right hand side. If still full of water it should all drain away when you remove the filter. Some machines will dump the water if you lay the drain hose on the floor, or out the door if close enough.
After removing the filter check the impellor is free, use a torch to see & screwdriver to rotate impellor, it is correct to have resistance to movement then flicks away from screwdriver, will then turn approx 1/2 turn backwards before resistance is felt again. If the impellor will not turn by hand you will need to remove the pump, they can get hair ties etc caught behind the base of the filter housing.
Aug 07, 2010 | LG Washing Machines
Caught or broken ribbon of cassette
Make sure your ribbon is tight going in. Look at the bottom of the tape, and spin the two winding wheels to remove any slack. Next, I would get yourself a wet head cleaner kit from Radio Shack. Or, get the solvent cleaner in a can, and some long swabs to clean the heads, pinch roller and clean the tape path spindles. Some where in there, you have some debree. Note: this is as far as one would be able to go before going to the repair shop.
Jul 09, 2009 | Sanyo VWM-800 VHS VCR
Wheel is not setting up to type correctly
The keeys were getting caught in the plastic guide. Tood guide off and now no more problem!! Thanks anyway!!
Jun 03, 2009 | Swintec Office Equipment & Supplies
Copier malfuntion.
I think we need a bit more information.....like make , model, where is the misfeed or jam (they are different) over to you
Feb 23, 2008 | Office Equipment & Supplies
Brother FAX-575 Plain Paper Thermal Logo
149 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
