Question about Dishwashers
The name of the part that holds the bottom spray arm to the water supply pipe in my Whirlpool dish washer.front load machine.
  • 10,865 Answers
Hello. here is a great link which will show you all of the parts and you can select the part you are in need of and even order it from that site if you choose to:
http://www.repairclinic.com/Whirlpool-Dishwasher-Parts
From your description, you may need the Middle spray arm water supply tube & arm kit.
Regards, Joe
PS - kindly rate my answer. thank you.
Posted on Feb 02, 2010
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
I have a built in whirlpool dishwasher. My problem is that dishes aren't being washed properly, there was water in the bottom of the washer, I removed and cleaned the filters ran the machine and the water...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchenaid dishwasher KUDP01IL upper spray arm not spinning although water supply appears to be adequate (water sprays from jets but the arm remains stationary).
Just had the same problem, and fixed it. Spray arms turn with proper water pressure in the pipes. 3 reasons can lower the water pressure. 1-pump motor losing power (wasn't my case) 2- cracked pipe (wasn't my case either, pipes, although plastics, seem to be very solid) and 3- debris in the pipes/filters. (It was my case) At first, it looks difficult to reach de filters, but it isn't.
1- Remove both baskets, the top one by removing the front plastic cap on the rails.
2- Remove the "+" bottom spray arm, by unscrewing counterclockwise (if I remember well...) the plastic screw dead center of it (use your fingers.)
3- Remove the three screws you see, but don't try to remove the filter part right away because there is a 4th screw under the leading water pipe, the one leading water to the top spray arms.
4-To remove the 4th screw, you must remove the plastic pipe that connect with the top spray arms. Easy. It's beeing held there by two clips, one on the back wall and one on the top wall. Just spread them with your fingers (or screwdriver) and turn the pipe toward the right side, to free the bottom part of the pipe from the middle/bottom spray arm holder, you'll have to bent it a little so it passes over the heating element.
5- Remove the last screw. Now there's nothing holding the bottom part anymore. just remove by moving it back and forth left and right (to loose it up), be carefull not to lose the clear plastic washers on the main shaft when removing. Now if your dishwasher is like mine (should be) you should see a lot of debris that couldn't reach the chopping device. In fact, the water couldn't flow properly because of all the debris stocked there by the bottom drain filter. Patio screws (?) small chicken bones, etc...
6- If you can find something to pump the water resting at bottom there, (I used a Prestone coolant tester!) you'd have a better view, and could remove the single screw holding the chopping device cap in place. That's the last step. Notice that the chopping device cap, even after the screw is removed, still look like firmly attached, like "glued", but there's absolutely nothing else holding the cap. Just shake it with your hand and it will eventually come off. Now you remove all the dirt/debris you see there, and then follow thw step back the rebuild the washing machine. On my part, it brought it back like if it was brand new..., but, now I'm being a little more carefull about the stuff I'm putting in there...
I hope it can help, English is not my first language.
Good luck
Daniel
Montreal, Canada
Dec 15, 2010 | KitchenAid 24 in. KUDP01IL Stainless Steel...
Dishes constantly come out dirty.. What temp should the water be while the dishwasher is running?
Supply water temperature should be above 120 degrees F for effective cleaning. Run hot water from your kitchen sink (your dishwasher should be tapped off the hot water line near your sink faucet) right before you start a dishwashing cycle to make sure it's as hot as it can be when the dishwasher begins filling. Also, during the wash cycle the heating elements at the bottom of the tub may turn on and warm the water further even if you select a "No Heat Dry" option causing a noticeable shot of steam to escape if you open the door during a cycle.
Note: I recently had a problem with our dishwasher (Frigidaire FDB834RFS0) causing dishes to come out dirty and the detergent dispenser to be left with undissolved detergent. Our problem happened to be caused by a partially clogged strainer in the water supply valve. (I would imagine Whirlpool most likely has some kind of filter/strainer in its water valve as well.) When the supply valve was commanded to open for some time, I noticed the water level in the tub would barely be visible below the lower spray arm. After cleaning out the strainer (required removing and disassembling the water supply valve) the water level was noticeably higher -- almost at the bottom of the float or about an inch below the heating elements. Our dishes and the detergent dispenser are now clean.
If your water supply is ok, I would next check to make sure your spray arms do not have any plugged holes and that they rotate freely. Also, use a good quality detergent and a rinse aid. We prefer liquid Cascade and Jet Dry. We have had problems with old, stale, or really thick liquid detergents and by getting a fresh jug have solved the dirty dish dilemma.
Make sure to clean out the filter basket at the bottom of the basin below the lower spray arm occasionally as it can clog and cause the pump to starve due to lack of water. If the pump can't get a supply of water to pump to the spray arms and nozzles, your dishes will not get sprayed evenly and you will end up with them being poorly cleaned.
Hope this helps you out...good luck!
Nov 18, 2010 | Whirlpool Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
The bottom spray arm gets jammed in lower dish rack.
I would unscrew the cap and remove the whole thing... you might have something clogging one side, which makes more water come out on one side than another, causing it to wobble... or you may find something else causing the problem.
If there is a blockage, clearing it out can be tricky. really long pipe cleaners work well. Craft stores have them.
Jul 25, 2009 | Whirlpool Dishwashers
MY KITCHENAID DISH WASHER TOP SHELF IS NOT CLEANING AT ALL .
There may be something plugging up the arm that sprays over the dishes. And of course, I'm sure you know not to place items like bowls, pots, etc that will block the flow of water from the bottom sprays.
Although the bottom jets do most of the working cleaning the top items, the spray from above is vital. Take the stem pipe leadin from the top to the bottom off and separate the spray arms carefully. If you can, look throgh each end to make sure no deposits are in there.
Another way is to blow compressed air from the center stem down in the water supply unit. If food particles are there you'll see them.
May 14, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
The arms do not spin and no water is going through them
Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
Post here is you would like more assistance. Good Luck!
Apr 11, 2009 | Dishwashers
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Owen Barnes
