Question about HP OfficeJet 4255 All-In-One InkJet Printer
Torn drivers cd - HP OfficeJet 4255 All-In-One InkJet Printer
  • 10,865 Answers
Hello. This is no problem because you can download a free driver off of the internet. Just google the brand name and model of the printer and add the words driver. Once your hits appear be sure to select a free driver that is compatable with your operating system. For example Vista or Windows 7.
PS kindly rate my answer. thank you.
Posted on Feb 02, 2010
    Sergeant:
  • HP Expert
  • 424 Answers
Posted on Feb 05, 2010
Door won't open of Technics SL-CH900
Hi Robert,
probably the cd tray belt (a tiny black rubber belt that connect the tray rack with motor gear) is broken, check this by opening the player, if torn you need to buy a new spare and replace it.
May 30, 2016 | Technics Audio Players & Recorders
I have a problem with paper gettin stuck and the calculater wont let me feed it paper through
If you can see the torn paper try using a long, thin screw driver or stick(like a wooden skewer) or possibly use compressed air.
If you can't see the paper the machine will need to partially disassembled to locate the blockage.
May 02, 2016 | Office Equipment & Supplies
How do I get a stuck cd out of the RCA RS22162?
the belt might have torn you have to open the system push the cd out carefully
Feb 16, 2015 | RCA RS22162 5-Disc CD Audio System with...
Cant remove driver seat headrest 2005 Grand cherokee limited
there is a small hole on the side of the bezal on the seat top look on both sides
Jun 30, 2012 | Jeep 2005 Grand Cherokee 4dr Limited 4WD
Cant install driver for deskjet 3915
did you use 39xx series driver? Torn on your PC, insert the CD Driver, plug the usb printer cable in, the PC should detect finding new hardware that is HP Deskjet 3915. When asked to install driver, chose install from CD. Follow the instruction and good luck
Apr 10, 2010 | HP Deskjet 3915 InkJet Printer
I have a CD stuck in the 6 CD player causing the player not to work. Can I remove the radio CD player front cover to unstick the CD and how do I do it ? I have a Saturn ION 2003
check the wires in the back to ensure there is no cut or torn wires this is a common problem with all cd changers you will need to take apart the cd changer there is a lever connected to s spring which will unlock the cds
Nov 03, 2009 | 2003 Saturn ION
I have a 1990 Nissan maxima that has been leaking a dark brown fluid on the rear driver side. It smells like gas when u walk up on it but had it checked for leaks and mechanic said there were no gas leaks....
your maxima is a front wheel drive. a torn boot would leak grease,and it would be in the front.
the leak could be old gas with rust in it... take it in and pressure test the fuel system,also check the fuel filter.,especially if the car cranks for a few seconds before starting some times ,that means there is a pressure drop..
Jul 23, 2009 | 1990 Nissan Maxima
3210 paper wil not feed in the printer it not jam it just will not feed
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
If there is no torn paper or any obstruction then follow this
  • Place 20 sheets of paper in the printer ensuring none of the paper is torn .
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually .
If your problem is not solved yet then follow this
  • Uninstall the printer driver and restart the computer.
  • Re-install the printer driver
SAM ANDERSON
Sep 16, 2008 | Computers & Internet
HP OfficeJet 4255 All-In-One InkJet Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
