Question about Toshiba Satellite A135-S2276 Notebook
Rebuilding Toshiba Satelite Pro
I would like to erase my hard drive and reload Windows Vista from the inbuilt programming on my Toshiba Satelite Pro. We were told by the supplier that we had to restart the computer then press Alt and 0 together to enter the recovery option. This does not seem to work.
Can anybody offer me any advise on this?
Regards,'
Charmaine
    Genius:
  • 3,587 Answers
Hmmm..do you have your files backed up first?
Posted on Feb 19, 2008
Toshiba Satelite Asos screen is blank after logon
This indicates a hard drive problem, but! first remove the hard drive and re-seat it back in place, "sometimes it goes out of position" and is enough to restart it, if no change! use your recovery disc to reload windows. Now! if it fails to load up chances are it is probably a bad hard drive, but I recommend having it tested before replacement of the hardware.
Apr 01, 2011 | Toshiba Satelite 5205-S505 Notebook
Hi sir how are you? sir when i on notebook toshiba satellite pro p300-19q model-009005en it come up with password screen enter HDD PASSWORD sir please help me so nice of you ibmlaptop111@gmail.com
The only way to remove the password is to format and erase the hard drive. All data will be lost in the process.
Use this software to format and erase all data on the hard drive and remove the password.
The software (Darik's Boot Nuke) must be burned to a CD and run overnight.
Windows will need to be re-installed after this process is completed.
Jan 24, 2011 | Toshiba Satellite Pro L300 Notebook
Hi.....I can't get my Toshiba Satelite M200 to shut down. The blue screen keeps stating shutting down but it goes on for hours. I am using Vista
Windows is so corrupted that it can't shut down properly. The only way to fix that is to save your data and reinstall. And be very careful what program you load after that because it was one of them that has corrupted Vista so load them one at a time with serious testing in between.
Dec 21, 2010 | Toshiba Satellite Pro L300 Notebook
I CANT GET ANY AUDIO SOUND ? HOW CAN I INSTALL SOUND DRIVE?I CAN SEE PICTURES IN MY LAPTOP BUT CANNOT HEAR ANY VOICE. MODEL NO. OF MY LAPTOP IS PSLB0E-02D01HAR SATELITE L300-129 SYSTEM UNIT, TOSHIBA
check that the volume control is not muted by going to control panel -- audio -- volume control and untick the mute button.
Otherwise try to reload the sound driver in control panel -- audio -- advanced - update driver
Hope this helps. It is hard to give exact intructions as you have not provided the details of your windows version.
Please rate the solution to help fixya serve you better in future.
Oct 15, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satelite p200-ab1 formatted drive which previously had windows vista and now want to load windows xp but will not recognize a drive to load to. if I try nto reload vista it will take but why not...
Before you attempt it, make a couple of changes in the BIOS to hopefully work around a few problems that might crop up.
At reboot, tap the F2 key to enter setup that will allow you to make a change in the BIOS.
Disable caching module before you change the drive sata settings.
Set the hard drive to "ATA compatible."
Aug 08, 2010 | Toshiba Satellite P200-0TD00Y Notebook
How do I wipe my laptop hard drive and reload Windows
If you have the Operating System installation CD, when you insert it -- you can reinstall your entire system as it does erases all your personal files etc.
Mar 30, 2010 | Toshiba Satellite P105-S6104 Notebook
When reloading windows and you are on the blue
Probably the problem is in the RAM, first open the RAM(s) and clean its both side copper teeth with a pencil eraser and try to setup XP. If not works then replace the RAM(s) and try again. Thanks.
Oct 27, 2009 | HP Compaq Presario C727US 15.4" Notebook...
Hi,toshiba satelite pro L20 beeps when start up
Run check disk for hard drive errors. I recommend immediately backing up all your data that you can, wiping it, and reinstalling your programs. The rebooting problem smells like a bad hard drive. I just went through it with a Compaq at work.
Sep 16, 2009 | Toshiba Satellite Pro 6000 Notebook
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
