Question about Whirlpool Duet GHW9150P Front Load Washer
Beeps and says f dl and water is in the washer and it will not drain
  • 5,911 Answers
"Fdl" is a door latch error code. This could be an indication of a door latch failure, or a defective relay on the Central Control Unit (CCU) that controls the door latch.
If you cannot get the door to open, there is a manual release you can use to open the door. The following link explains how to access:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
Make sure you UNPLUG the washer before servicig inside the unit. In some cases, using the manual release can return the washer to normal operation. However, if you still have problems there is a tech sheet inside the appliance that explains all the error codes and how to troubleshoot them. The test points required to diagnose the problem are also included. The tech sheet should be located directly behind the lower toe panel, or affixed to one of the interior cabinet walls. I would begin by checking all the interconnecting wire connectors between the CCU and door latch to ensure the connectors are all seated properly. Unplugging them and reseating each one can help.
If you determine the door latch to be the cause of the problem, the following link explains how to access and replace:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacement parts (if required) can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancpartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Feb 02, 2010
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
We have a duet washer wfw9200sq00 and it won't power on - just gives 3 beeps. I did get a F71 error code
F-71 user interface heartbeat failure, com failure between touch pad and central control.
You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
Service manual for duet with repair photos
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
DL error or kenmore Oasis washer
Hi. this is a door lock mechanism failure code. these mechanisms will become unstable overtime. simply replacing this damaged door lock assembly will fix this issue.
If you are uncomfortable with disassembling thsi unit, i recommend calling a service tech for this procedure. he will simply replace the door lock mechanism(assembly)
Jul 27, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
