Question about Apple iPhone Smartphone
Why doesn't my iphone ask for a password to join my 2wire?
Try resetting network settings and try again it should work. the password remember is the number in brackets on the modem itself
Posted on Feb 03, 2010
When asked for password on iphone it will not take password. how do i change password
if your referring with the wireless password
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
check the links out
and if referring about the network key:
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
Aug 23, 2011 | 2wire.net
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
Where is the wifi password for my 2wire wireless router. trying to connect my iphone 3g for faster internet
the default wireless passowrd or network key is located at the bottom left of the 2wire router. You will find a sticker that indicates the Serial Number, System Password and Wireless Network Key. The Wireless Network Password is is the 10 Digit Code located under the S/N.
If in any case you want to personalize the Wireless Network Key. You can access the gateway by opening a browser the type 192.168.1.254 it will ask you for a password use the System Password on the sticker. Click on Home Network then Click on Wireless Settings. You can also change the Network Name or SSID, The Authentication and the Wireless Network Key
Thanks for using Fixya
Jul 29, 2010 | 2wire 2700HG-B Router (2700HGB)
Why wont my 2wire router find my iphone anymore? It used to connect, nothing's changed on my computer or iphone but the wireless light is not coming on when the iphone tries to join network.
Has the router been reset recently?
If it has, this could be the issue. Check the installation instructions or website for known issues relating to this.
Hope this helps!
Jul 08, 2009 | 2wire 2700HG-B Router (2700HGB)
Ipod touch connection using 2 wire 1800HG
Check your router or the modem's settings. I had the same problem but when I tweaked with the modem, it worked.
May 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Cannot get 2wire to work on my iphone! :(
Try this one:
>on ur WIFI networks, click "other..."
>then manually type in ur network name (if its set to default, it should be 2WIRE and the last 3 digits of ur SN. It is case sensitive so type the name exactly how it looks like.)
>make sure that the setting is set to WEP
>on the password box, enter a dollar sign/$ first and then the 10 digit code under ur 2wire
keep me posted on this one
Aug 30, 2008 | 2wire (1000-400106-003)
Cannot connect IPhone to 2wire :( HELP!
I had this exact same frustrating problem. The problem was a simple password issue. Although I had changed the password on the modem to my own personal one, that password only affected the administrator settings. When I used this particular password on my iphone it would put the checkmark next to the 2wire, but I would not get the wifi symbol at the top of the screen. I fixed the problem by using the 10-digit password supplied on the actual router instead. I told my iphone to 'forget' the network, then reselected it and when it requested my password I typed in the 10 digit number and 'presto,' i had wifi symbology! I hope this helps.
Aug 28, 2008 | Apple iPhone Smartphone
Iphone wifi
You need to select the 'Settings' button on the home screen, then make sure that the 'Ask to Join Networks' option is turned on. Choose your network, and then enter in your password. I've had the same problem before, and it turned out that my phone wouldn't connect without setting the computer to require a password. If this doesn't solve your problem, please let us know.
Feb 20, 2008 | Apple iPhone Smartphone
Wi-fi
you may not be able to join these networks as these networks are from your neighbourhood who have protected them by passwords. you may try 12345 as somebody might have kept this default password. But again you can not access networks protected by passwords unless you know it.
you may ask your friend or neighbour who can share his net with you.
Nov 25, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
161 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
