Question about Brother MFC-5440CN All-In-One InkJet Printer
Mfc5840cn can't turn on.. it shuts down immediately
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
I replaced my bulb and it does not seem to be working. The projector power turns on then shuts off immediately
a short circuit in one of the power lines on the mainboard is most of the time the reason for immediate shut down
check all smd capicitors
Apr 03, 2010 | Eiki LC-XE10 Projector Multimedia...
Windows 7 upgrade cripples Scan on Brothers MFC5840CN - I think.
Please check the compatability list here ... http://www.microsoft.com/windows/searchlp.aspx?CMXID=2120.BF7510CA-BAB8-4BB0-B922-4C18EFE72232&WT.srch=1&category=Windows_7_Info for an answer to your question.
Thanks for your interest in FixYa.com
please vote
thanks
a
Dec 03, 2009 | Computers & Internet
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
New Samsung sch-430 won't shut off
try taking out the battery for five minutes
Mar 30, 2009 | Samsung SCH-u430 Cell Phone
1997 Sunfire real slow to crank, shuts down immediately
I would recommend having the ignition module tested. I have had one of these vehicles with the same problem and that is what fixed it.
Sep 30, 2008 | 1997 Pontiac Sunfire
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Brother MFC-5440CN All-In-One InkJet Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
