Question about Maytag Washing Machines
How do i remove top on maytag # la212? - Maytag Washing Machines
    New Friend:
  • 11 Answers
I'm sure you already have resolved your issue, or gotten a completely different washer. I'm posting this answer because I now have the exact same model and someone else may also need/want to know this answer.
  1. On the front of the washer, at the bottom there are two screws. Take these two screws out.
  2. The front of the washer will now pull out from the bottom. Pull it out and the front will unclip from the top. Set it to the side.
  3. Now you will find two bolts, one on each side of the washer at the top. These bolts hold the top of the washer to the sides. Remove these.
  4. The top of the washer will now lift up, and you can carefully lay it back. Be careful the door will open as it is laid back.
  5. This should be as far as you need to go to work on the drain. In my case, I needed to replace the Siphon Break. It was leaking causing water to leak out under the washer.
  6. If you wish to remove the top, you will need to unplug the wires that remain. The top will lift up and come off the washer.
Posted on Dec 28, 2012
  • Thomas-Laura Moore
    Thomas-Laura Moore Dec 28, 2012
  • 254 Answers
Some of these older models are sometimes difficult i dont wanna stear u in the wrong way i couldnt really tell yu without lookin at it...
what i can do is direct you to sears.com,,,,, go to their parts direct section i belive under parts...... type in you model number and it will give you the parts breakdown diagrams/ schematics
Posted on Feb 02, 2010
How do I take the black plastic agitator off so I can get the drum out of my Maytag LA212 Series number 423621
Never seen a black agitator how a photo of what you are trying to remove if it is black sounds like the tub ring
Jan 19, 2015 | Maytag Washing Machines
Do you have a wiring diagram for install a maytag washer water valve? the washer model is LA212
Sorry but this forum does not supply operation and service manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Also may I suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C
Mar 06, 2011 | Maytag Washing Machines
I have a Maytag LA212 AND a Maytag A8120 washers that will both fill but then do nothing else. The A8120 I got first and it just started this behavior last night then then today someone put out the LA212...
I used to have 2 laundromats full of toploader Maytags... these will fill and do exactly what is happening to you if the LID SWITCH is not activating. Open and close the lid and listen for a clicking sound. Look a the rear edge of the lid... there is an indentation that is supposed to activate a small white switch in the that's attached to the top of the machine. Many times the lid will simply get bent.. someone sitting on the lid, standing on the lid... will be enough to throw it out of whack. Close the lid and push on the center of the closed lid... will the machine work? Or carefully push a flatblade screwdriver tip between the lid and the switch to see if you can get it to activate. Solution: Open the lid and apply firm pressure on the lid towards the back of the machine, while with the other hand push DOWN on the back edge of the lid...right where the indentation for the switch is... if you give it a slight tweak...you'll probably be back in business. One other thing, if the lid switch isn't clicking...replace it.
Sep 12, 2010 | Maytag HAV2557 Top Load Washer
How do i remove the drum on a maytag top-loading washer.MAV 7000aww
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Jan 30, 2010 | Maytag Washing Machines
How do I remove the top on a Maytag range
Unplug the range from power.
Open the oven door. Look on the right and left sides of the oven frame just below the top. Remove the 2 screws. Pull the top forward. Remove the wiring harness connector at the back.Lift the top up and off. Set the top aside.
Nov 11, 2009 | Maytag MER5775Q Electric Kitchen Range
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
Hoow do I remove the top froma maytag range?
there should be two small screws on the corners thay are black so you really gotta look
once removed your top should flip up
Sep 30, 2009 | Maytag 30" Self-Cleaning Freestanding...
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
Nov 02, 2017 | Maytag Washing Machines
Washing Machines Logo
306 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
