Question about MSI NX7300LE-TD256EH GeForce 7300 LE, (256 MB) PCI Express Graphic Card
Multiple display problem
I have installed the MSI nx7300 td256eh and downloded the drivers form the MSI site. I think its a LE but the card only has NX7300 TD256EH on it S/N is 602-V027-250B0705304953.
No matter what I do the only way it will recognise a second display is when I force TV settings both moniters are brand new and both work as the primary display.
the card only displays of the VGA analogue port the digital has an adapter but will not display.
any thoughts would be appreciated
When put on the computer there is power but the screen iis black
Posted on Jun 22, 2008
Qwdwd
Posted on Feb 20, 2008
    President:
  • 2,351 Answers
Hello. Your driver software was 71.6MB large. It not only included the driver software but secondary software for you to control & setup dual monitors. The package came with a HDMI connector which is used to connect the HDMI femal port to VGA port, if the monitor does not have a HDMI male port. Currently the reason you can not see your display is because the signal comming out of the video card is set to the other port on the card. Once you switch to the other port you'll have display on your monitor. Open control panel, than open display. Display Properties will open on your desktop. Click settings than click advanced. You should see another tab that reads something like, NVIDIA® nView Multi-Display Technology. (I'm guessing because I only use ATI's software) I can't load your driver software on my current system. The two cards may be different but the software is similar. This Nvidia tab is where you set up your monitor or monitors. Once in this advanced portion for your video card you can set which connector from the video card will display on what monitor. There will also be a ton of settings you can adjust, from color to 3D & other options. You must have an icon by your clock as well that allows you to open the standard display properties or the advanced display properties.
Posted on Feb 19, 2008
  • 1 more comment
  • Mike Peluso
    Mike Peluso Feb 21, 2008
    I am currently waiting for an email from MSI tech support who is going to explain a bit about your MSI video card. I gave them your serial number of your video card that you listed above.
    I hope this answers your question
    Email responece:
    Dear Customer,
    Unfortunately, because the DVI and VGA Port is shared with the dongle (Cable) going between the DVI and VGA Port you cannot extend the desktop only Clone it..
    Thanks Bryan Bastian
    Bryan Bastian
    MSI Technial Support Department
    Technical Support Engineer
    1-626-581-3001 x 179
  • Mike Peluso
  • Mike Peluso
    Mike Peluso Feb 22, 2008
    You want a card that will extend you desktop across dual monitores! Try this link:
    http://www.zipzoomfly.com/jsp/ProductDet...
    Comes with a Lifetime warranty.
NX7300LE-TD256EH may dvi dont work but vga work i have windows 7 ultimate and like to use dvi to may lcd hanns.g 19 wide vga please help me
Try installing the latest drivers for your graphics card, who knows it might work. See my guide to install the drivers. The section on Nvidia drivers applies to you.
How to install Graphics Drivers, Nvidia and AMD Radeon!!!
Remember to check that you screen is good and not faulty, try it on another computer with DVI if you can.
Take care!
damnor01
May 05, 2011 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
After i install the driver and restart my computer windows is loading but at the logon screen the screen goes black and shows a message that says unsupported input
http://www.msi.com/service/download/
How did you install the driver? If you used installation cd, it may be outdated. The link above is for MSI and if you click on'"live update online", they will scan your computer and suggest any updates. I'm guessing this wasn't a first time install so you also have to make sure that whenever you want to update your card, you first have to uninstall any prior software then, intall new software.is your model actually NX7300le-TD256EH. Let me know at "add a comment"
Mar 21, 2011 | MSI NX7300LE-TD256E Geforce 7300LE 256MB...
Hello, Sir my msi graphics card stoped display ,,i don;t know whether it needs vga bios update or what. when i saw it by turning my pc off it got hot . some times it gives the display but everything big...
hi mrafigkundi,
because you chose to repair by yourself then i will suggest this steps
#1. see if you plug cable data from monitor to VGA correct. if yes...
#2. detach your pci express graphic card from motherboard.
#3. see if some component burn, sometimes it located near pci slot, if it does then you have to change it.
#4. if none of component burn, put again in your CPU
#5 your problem can caused by memory chips defect, you can test it with memory test, its running under dos so you have to reboot it with bootable CD and run VGA memory test.
Mar 12, 2011 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
Hi i need Driver Graphic Card MSI
http://eu.msi.com/index.php?func=downloadindex
Apr 23, 2010 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
Need free downlode Msi MS-6526 v2 driver
open link and download driver ................
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=491
Nov 06, 2009 | Computers & Internet
ACTIVATE MY VGA
need to go on line to the manufacture and request updates and activation and it will be done automatic every few months, there are free software at pcworld.com and other pc magazines download center of free update software update and drivers update and any or new software fixs that will improve the performance of your equipment and operation on the system.
Feb 26, 2009 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
NX7300LE-TD256EH
hi there im wesley. ok it might be that the card is having trouble giving power to both the tv and monitor please make sure your power supply is powerfull enough and that there are no loose connections inside your box.
Jul 16, 2008 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
Nero 7 ultra
Your installation package file is corrupted. ".cab" mean cabinet file that has many files in compressed form within it. Try different source to install.
Mar 30, 2008 | Computers & Internet
MSI NX7300LE-TD256EH GeForce  7300 LE, (256 MB) PCI Express Graphic Card Logo
882 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
