Question about Sony KP-65WS500 65" Rear Projection Television
Sony 65 inch rear projection
Sometimes the TV will come on. Others it will have the standby light blinking sometimes 5 times sometimes 11 times. I don't know what to make of it, like I said sometimes the TV will come on. Can someone help please?
  • 808aloha Mar 13, 2008
    Mine's blinks 10 times. It has sounds, but no pictures and the standby blinks 10 times.
  • Sony Master
  • 5,138 Answers
I just have fixed one just like this i replaced relay and 47uf cap next to relay, this fixed the sony, like yours it would sometimes come on and play 3 days with no problem then turn around and set would not come on. ThankYou for trying FixYa. Have a Nice Day.
Posted on Feb 19, 2008
Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Sep 17, 2009 | Sony KP-44PX3 44" Rear Projection...
SONY KDP-65WS550 projection or power problems NEED HELP
3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. got this off a website that had Sony codes listed.
Rusty
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Sony 11 blinks
Blink code only goes to 8 on this model. Are you sure its not 5 and 6? That would be AKB and Horizontal stop, respectively. Quite likely a flyback transformer on this model.
High Definition Projection TV
The flashes are a diagnostic. It should be only one flash pattern, either a 5 or a 10 (there are several other patterns in between as well). Please verify the number of flashes after power on, several times, and post back here, and I will be able to help with the fix. Based on your initial description, it my be the HV distribution.
Apr 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
