Question about Car Audio & Video
How do you wire the PIONEER PREMIER TS-W3002D2 12'' to 1 ohm
4 Suggested Answers
sticky92505
  • 77 Answers
SOURCE: Wiring diagram for Pioneer TS-W3004SPL subwoofers
a good resource for wiring and information on the web can be found at 12volt.com
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: wiring diagram for a pioneer
go to goolge or youtube and type that in and it should give it to u
Posted on Mar 11, 2011
Darkseid007
  • 29 Answers
Hope this will explain a little better detail than the previous poster made.Least taking the time to do the footwork to get what is asked.
TS-W3002D2/D4 model is a dual voice coil 2 ohm (D2) or 4 ohm (D4) speaker.
This is for wiring a dual voice coil 2ohm and wiring to a 1 channel amp making the speaker into 1 ohm in parallel for this video.
Woofer Speaker Installation Tips Woofer Speakers Bridge Dual Voice Coil
(Note) he said he was doing in series, but that is incorrect. Hope this helps others.
DARK
Posted on Apr 21, 2014
Wire 2ohm or 4 ohm
wiring depends on what amplifier you're using..
Dec 28, 2013 | Pioneer TS-W3004SPL Car Subwoofer
Manual Pioneer TS-SW1241D
Hi:
I suggest visit this links:
- pioneer-latin.com/en/operating-manuals/mobile-electronics
- manualowl.com/p/Pioneer/TS-SW1241D/Manual/18391
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 01, 2012 | Pioneer PremierĀ® TS-SW1241D Car Subwoofer
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer PremierĀ® TS-SW1241D Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Connection Pioneer TS-W65A
you are probably looking at a dual voice coil subwoofer. This means you have many options of wiring in series/parralel/or bridged parralel. Go to either www.the12volt.com or crutchfield's learning center in order to figure out what your options are. Then you need to find out what ohm your subwoofers and what ohm your amp is stable at.
May 05, 2009 | Pioneer TS-WX65A Car Speaker
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Car Audio & Video Logo
433 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
