Question about HP Jornada 540 Pocket PC
Msfeedssync.exe has generated errors and clossing by windows. errorcode is 805306296
C bizzar cher pas!
Posted on Mar 17, 2010
Windows error code 805306296
Have you removed your previous Anti Virus with the Manufacturer's Anti Virus Removal Tool found on that Anti Virus's website? This may help with the error: http://www.pcadvisor.co.uk/forums/1/helproom/362835/doctor-watson-and-more/
Dec 15, 2012 | Dell Dimension 2350 PC Desktop
Setup.exe is not a valid win22 application
You may see Windows error code 193 (%1 is not a valid Win32 application. (Code 193)) when you are starting a Windows Share Point server or a Windows Exchange server. The error message will also generate general Service Control Manager messages in your system logs, too. Error code 193
Aug 27, 2012 | Remington Rem Mod 715 308 Win 22
AppName: msfeedssync.exe, AppVer: 8.0.6001.18702, ModName: user32
Antivirus and firewall prevent msfeedssync to connect.
You can use next 3 solutions (hope this help you):
NOTE: Before using ones of the next 3 solutions. You can test disabling your Anti-virus and check if the error occurs, if yes, then disable you firewall. But only for testing, AFTER test enable both AV and FW and select the solution from above that suits you better.
1. Disable the app:
Run CMD
and type: msfeedssync disable
2. Disable automatic update in IE
Internet Options - Content - Content Advisor -
"Sources” “Configuration” and disable “Search..."
3. Configure your Anti-virus and Firewall.
It depend of your software used, for the firewall you need to allow connections for msfeedssync.exe located in, C:\Windows\System32
Regards
Mar 01, 2010 | Microsoft Windows XP Professional
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
Why am I getting error message for Microsoft Feeds
This is a problem with Microsoft's RSS Feed Reader. As most people use a different Reader (or don't use RSS at all) this can be disabled. Please follow the instructions below to disable it.
Open Internet Explorer.
Click Tools>>then Internet Options.
Click on the Content tab.
At the bottom, under the Feeds section, click Settings.
Uncheck all boxes and click OK.
Click OK to close the window.
Close Internet Explorer and reopen.
Nov 20, 2009 | Microsoft Windows XP Professional
Feeds synchonization keeps appearing i delete it but it returns every 2 min regardless of what i am doing it does not seem to stop anything working error report is feeds synchronization appname...
This is your IE browser checking for updated rss feeds...you can disable it if you wish to... or adjust the frequency with which it checks for updates
In IE,
Go to Tools\Internet Options
Select the Content tab
Settings button in the Feeds section.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 25, 2009 | Microsoft Windows XP Home Edition SP2
Power window, passenger side is not clossing would
If the window will not go up or down here is what I found it to be from experience.
1. Simply the window motor has burned out and it needs to be replaced. Which is a common problem on first generation G35 coupes and sedans.
2. The window sub switch does not work properly (switch that has the unlock/lock button and window up and down button) it is a white box that needs to be replaced.
Jul 11, 2009 | 2005 Infiniti G35
My Computer will not login or activate
You have to re-install your OS using the correct key.
The MS web site will assume that you have a pirated copy unless you use the correct key provided.
that is why it failed the genuine advantage test.
You need to scrub the drive if you cannot access the install from the disc. You can purchase drive scrubbing software at many outlets or online.
May 07, 2009 | Computers & Internet
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: IntelĀ® Chipset Software Installation Utility for IntelĀ® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
HP Jornada 540 Pocket PC Logo
97 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
