Question about Sport & Outdoor - Others
My mr heater model mhc will start ok but after a short while ( 1 to 5 min ) it will shut off. what do i do to correct the problem? this happened to a previous one and also to my sons heater. john
  • 311 Answers
It sounds like you have a bad thermocouple. The model number is not a complete model number so you would need that to order any parts. Another issue could be a clogged orifice however if this was the case you would have low flame even on a high setting.
Hope this helps _MJ_
Posted on Feb 02, 2010
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
My mr heater wont stay light unless its above 3. It only stays on about 5 min then pilot goes out. It is gas heater. What's wrong with my heater?
Theres a thermostat inside, if its too cold and not warming up the thermostat enough it will shut off because it thinks there is a problem.
Feb 07, 2013 | Heating & Cooling
Runs for about 1-1/2 hours (on either lo or hi) and shuts off. will not restart. try again in the morning and it starts... want to return as it's the first time to use and it doesn't work!!!!
heater has an oxigen sensor,if it i used in a small closed room and oxigen levels are getting low, heater will shut off for safety reason. Try to open doors or windows for a while and see if heater restarts.
Oct 04, 2010 | Mr. Heater Mr Heater Portable Buddy...
Big buddy heater caught on fire
HI try mr heater wed site there has been some recalls on these heaters , it sounds like you had too much pressure going to the heater , or the gas valve was faulty, hope this helps
Feb 09, 2010 | Mr. Heater Big Buddy Heater
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Feb 03, 2008 | Heating & Cooling
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
