Question about Crosley Stack-O-Matic CR40 Turntable
Brand new i got it yesterday the turnable will not turn i followed the instructions exactly it is plugged in right some times it makes a noise so i know it is plugged in
  • Crosley Master
  • 5,391 Answers
Contact the shop you got it from, it might have got damaged in transit.
Posted on Feb 02, 2010
Delonghi. Brand new out of box. Followed instructions. Machine making loud noise from pump. Motiva ec200
Sounds like the pump is dry, try and fond a way to blow some water into the socket where the tank plugs in.
Jul 17, 2015 | Coffee Makers & Espresso Machines
My blackberry phone kept asking for the password and after that it just went blank and said it was gonna wipe out all the info on my phone. Now I can not turn my phone on cause it keeps saying reload...
Hi Eric, Your device has been reformatted. Unfortunately, you have lost all your data. We can get you back up and running though.
1) download and install JL CMDER from here. https://rs468cg.rapidshare.com/#!download'468l32'143028674'JL_Cmder_v1.9.0.zip'105'R~0 (I want to wait in the bottom right).
2) Make sure on your computer you have the BlackBerry Desktop Manager installed. This can be downloaded from the BlackBerry website. (http://us.blackberry.com/apps-software/desktop/?CPID=OTC-DSKTPSW&cp=OTC-DSKTPSW)
3) Plug you device into the computer via USB cable - make sure desktop manager is closed.
4) Launch JL_Cmder and follow the on screen instructions: - Press any key - It does not lock with a password (n) - 4 for wipe - Y to continue - type BlackBerry - wait for the device to connect - it may take a few attempts, so just keep trying it.
5) Download the most recent BlackBerry OS - you can find it at this URL - http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads Make sure to select the right carrier.
6) Delete the following file - C:Program FilesCommon FilesResearch in MotionApploader endor.xml
7) With your BlackBerry plugged in, launch the desktop manager. Select Application Loader and install the OS using the prompts. It may take a long time for the first reboot.
If these instructions are not clear in any way please let me know! I would be happy to walk you through this process personally if you're not comfortable with any of the above steps! If you follow them all exactly, your device will work like it is brand new!
Best of luck! Alex
May 31, 2011 | RIM BlackBerry Storm 9530 Smartphone
Ok my power flashed off then back on yesterday now my Wii willnot turn on how do I get it to turn back on so can play?
Make sure something else plugged in the same exact outlet works to make sure it is not the outlet.If you unplug the AC adapter for 30 seconds then plug it back in it may fix the problem if you have a red light at least.If there is no red light you probably need a new AC adapter and even possibly manufacturer repair.Here is a link to help you out.Also,I used to repair Nintendos for an authorized center.If you do need an AC adapter,PLEASE make sure it is Nintendo brand or the packaging says 'Licensed by Nintendo' only.Anything else causes problems probably 90% of the time eventually if not right away.If you want to see my tips there is a good explanation which I put there because I have already typed it too many times.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/index.jsp
Good luck and game on!
Jul 24, 2010 | Nintendo Wii Console
New machine.....sewed fine yesterday. When I turn
The motor running noise is because your bobbinwinder is on. Flip the bobbinwinder to the right.
Rick
Bernina rech
(don't feel dumb, it happens to many)
Dec 06, 2009 | Sewing Machines
Yesterday, my 2004 Nissan Quest had the front end bushings and control arms replaced. The car still has a "knuckling" noise when I'm making semi-hard left or right hand turns. Forget about hard turns!! ...
it usually does but you have also an intermediate shaft that connects steering column to steering rack, I know those at times can cause the exact noise you describe although what you replaced usually does.
Sep 02, 2009 | 2004 Nissan Quest
I got instructions on how to CHANGE BRAKE PADS
You need to have the rotors turned and they can tell you if they are turnable or not. They must be able to turn them and keep them within certain specs insofar as thickness. If they are not turnable then you will have to purchase new rotors from an auto parts store.
Jul 08, 2009 | 2005 Hyundai Tucson
Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
May 28, 2009 | Korg Mini Kp Kaoss Pad
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Brand new Kenmore Front load won't work
It sounds like the plug is mis-wired. The panel works off of 110v but the rest is 220v. If one line is swapped with the ground you will get 110 only.
Jun 02, 2007 | Kenmore 85871 Electric Dryer
Crosley Stack-O-Matic CR40 Turntable Logo
210 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
