Question about Motorola Mobility W375 Cellular Phone
My Motorolla W375 - No Service
I have a motorolla w375 but i cant use it because when i put the sim card it seems that i cant signal for the network provider of my sim. it appears no service..what is the problem of my motorolla w375? thanks
  • 1 more comment
  • Anonymous Feb 20, 2008
    I 've got motorola W375 for present over from AU and when I inserted my sim card in, first ? is insert subsidy password which i don't have ( vodofone office too) how can i find and use my new mob. ph.?TA
  • Kadieh Aug 19, 2008
    i Have the same phone
    and in the state i live in we dont have this phone yet
    i got it for a present
    it worked for awhile then it started to say
    "emergency only"
    and thats all it says
    i cnt call or get me pic off of it
    so it useless
    but i want my stuff off or i want to use it again
    how do i fix this?
  • MrJimmy60 May 11, 2010
    Next time you guys post try checking "I have the same problem" check box and not the "Solution" check box. (which is probably the default if you dont check anything)
Posted on Nov 27, 2008
Posted on Feb 20, 2008
Motorola w375 in sert sim card salition
Its shows insert correct Sim means it locked to Network,You need to Unlock it from Network Lock,Get the Unlock code at here
http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock it...
Apr 20, 2011 | Motorola Mobility W375 Cellular Phone
Motorolla slvr wont recognize sim card
try taking the sim card out and put it back in...it could be network, tower or sim related....wait at least 20 seconds before putting battery back in..this reboot should help..if not, u should contact ur service provider....
May 13, 2009 | Motorola Mobility SLVR L7 Cellular Phone
I need the subsidy password for this nonworking verizon motorolla w375 and i want to use it on the metro pcs network here in dallas,tx and where is the iemi number
A request for a Subsidy Password means the phone is 'locked' to a specific network provider (SIM), so it's the same as an 'unlock code'.
Provided you've had the phone for the minimum time the contract runs for, you can request the unlock code from your provider - ie the network the phone originally worked on.
To obtain your IMEI number try entering:
*#06# in full (including asterisk) and the phone should display it for you. As far as I know you don't need the IMEI in order to unlock the phone.
Hope this helps - I'm not an expert.
Jan 13, 2009 | Motorola Mobility W375 Cellular Phone
Sim card removal w375 motorola
If you remove the back covering of the phone and then the battery, part of the sim card will be visible. It's a rectangular card about the size of a finger nail. Usually, you can push it from one side(sometimes on the outer edge of the phone) so that it slides out of the other side but some times it's held by a spring mechanism that needs to be pulled to one side so that the card can be lifted out
Dec 21, 2008 | Motorola Mobility W375 Cellular Phone
Motorolla W385
Most probably the pack CD would be having the required driver. If not, just get one from motorola.com Once motorola driver is installed, you can properly use the phone with your PC. If nothing works, let me know
Jun 03, 2008 | Motorola Mobility W375 Cellular Phone
Broken phone, SIM OK
The chances are that the W375 is locked to Net10. The other Motorola phone you mentioned will work with the old SIM if the phone was previously used on Net10, or has been unlocked.
Most phones, upon issue, are locked to the network that provided the phone. If the other working phone is locked to a different network, speak to the Network it was previously locked to, and ask for an unlock code.
Try it anyway, you can't damage anything by doing so.
May 08, 2008 | Motorola Mobility W375 Cellular Phone
Subsidy password
Need a subsidy password on Motorola W375, in Nigeria, I'm MTN Network. Can any help be given to me? because they are charging high amount to unlock it.
Chidi
Apr 01, 2008 | Motorola Mobility W375 Cellular Phone
Motorala w375 mobile
This may be because the settings for the network are not set up, was it working before? or is it a new phone??
Jan 23, 2008 | Motorola Mobility W375 Cellular Phone
Setting up instant message on the motorolla w385
call your mobile carrier to fix the msg problem that you are having
Service Problems
Try manually selecting a network with different SIM cards in - it may not be automatically selecting a network. Failing that, the phone may be an import, or it may be locked to one particular network. Either of which may be the cause of your problem. Let me know how it goes.
Sep 07, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
322 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
