Question about Olevia LT32HVE 32 in. LCD Television
New HDTV...using RCA Anttena hooked it up
New HDTV...using RCA Antenna hooked it up properly and ran scan to find channels but it say there are no channels or signal... had it with other TV before a recent ice storm
  • lapistolera1 Feb 02, 2010
    The Antenna is digital.
  • Olevia Master
  • 8,457 Answers
Buy digital antana,get stronger signal,will work for any wheather.
Posted on Feb 02, 2010
HOW DO I GET MY TV OFF OF THE CABLE SETTING SO I CAN USE JUST AN AIR ANTENNA?
There is a button on the remote which should be labelled "Input" or "source". With the TV turned on, press the button and there should be a list of inputs. Scroll to the input labelled TV or Ant.
Apr 10, 2014 | RCA HD52W59 HDTV Projection Television
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
I cancelled my dish hooked up a anttena but no signal
Go to main menu and select settings, initial setup, TV signal input, select Antenna, go to channel scan, select digital channel scan if there is a choice, or else channel scan. Wait for the scan to complete, 3 minutes or so. Exit menu, go to input and select ANT.
Wah Lah!
Jul 03, 2009 | LG 42LC2D 42 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Won't recieve digital channels
I have the same type of TV and as soon as i figure out why it also, will not convert from analog to digital ,I can hook up to converter box get all kind of clear channels I am quickly finding out These Sets Are either minor problems or very major problems. They have over 32 different SSB tuner boards,and they all look alike but are not, hookups and connectors are not the same.
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Installed and setup RCA DTA800 digital converter. Ran a channel scan and did not pick up any channels. Have an outdoor antenna with an amplifier. Need advice.
Try bypassing your amplifier. I was getting an incomplete scan, and that solved the problem. I ran the scan without the amp in the line, then turned off the TV and converter and reconnected the amp.
May 27, 2008 | RCA Televison & Video
Olevia LT32HVE 32 in. LCD Television Logo
211 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
