Don't know ipod volume limit code
I have an iPod Nano 2nd generation, and my son was playing with it and accidentally set the volume code, and doesn't know what it is....can I reset it?
  • 593 Answers
Go to the menu, to settings, and look thru the Settings menu for AVLS volume limit. I do not think there is a code just a setting to change.
Posted on Feb 02, 2010
How to remove volume limit on eu ipod nano 5g
You can set the maximum volume limit by going to settings then playback and then volume limit. This will show you the current volume limit, use the click wheel to select the maximum volume limit and then press the centre button to set the limit. Hope this helps.
Sep 27, 2010 | Apple iPod nano 5th Generation
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
Wish to remove eu volume limit on ipod nano 5th generation
Go to settings then playback and then volume limit. You can then use the click wheel to select the volume limit once you have the volume you want use the centre button to set, Hope this helps.
Apr 06, 2010 | Apple iPod nano 5th Generation
The volume on my ipod nano 4th Generation won't turn up all the way
You have the volume limit adjusted so that it won't blow your ear drums out.  Go into your settings and turn the volume limiter off.
Nov 24, 2009 | Apple iPod nano 4th Generation
I don,t remember the combo for the lock I put on my volume limit.How do i restore volume? I locked it accidentally on low .
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
Then go to Settings and then volume limit and change it to your required volume
Nov 04, 2009 | Apple iPod nano 2nd Generation MP3 Player
I need to the code for the model ma477ll
I forgot my code to my ipod how do i put in a new one?
Aug 25, 2009 | Apple iPod nano 2nd Generation MP3 Player
How do i over-ride or reset the maximum volume limit on the nano 4g
ok maximum volume on the ipod will only work if you change it yourself. if you havent tried this yet, turn on your ipod then select settings then select volume limit and set it to whatever you want. if this doesnt work you can plug in your ipod and open up itunes and change it from there. the way you do this is right click on the song and click get info in the tabs select options and then you can set the volume limit there as well u can aplify the volume or change lower it
Jul 08, 2009 | Apple iPod nano 4th Generation
Reset ipod nano code
restore your ipod using itunes, and it should reset that pass word
Jul 25, 2008 | Apple iPod nano
Ipod nano 2nd generation won't fast forward
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
May 21, 2008 | Apple iPod nano 2nd Generation MP3 Player
Problem unlocking
need help lock 8gb ipod need big help now
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
208 people viewed this question
 Grubhead
Grubhead
