Question about Refrigerators
I have a GE GSS22WGMDBB refigerator the ice and water in the door won't work. The display board on the door is dark. The refrigerator makes ice internally but will not dispense ice or water thru the door. ShouId I be able to check for voltage at the leads behind the display? How do I know if it is the board or something else?
  • 3,037 Answers
If there isn't any voltage going to the board, then the board is generally ok and you have a different problem that then needs to be tracked down. If there is voltage at the board, then the board is bad and needs to be replaced. I assume that you have a multimeter to check for voltage, otherwise an electronics store will have one.
appliancepartspros.com will have good diagrams for your unit that you can check out if you need help figuring out how to dissemble it but I have found that repairclinic.com generally has cheaper parts if you need to order a new board. Just use your model number to find the diagrams/parts on the two sites mentioned above.
Let me know how this works out for you.
Benjamin
Posted on Feb 02, 2010
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE Refrigerator Ice and Water dispenser stopped working after power outage
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
May 19, 2012 | GE GSH25SGRSS Stainless Steel Side by Side...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
The control panel on the door does not seem to work properly. When Cube is chosen, no cubes are released. Same situation for crushed ice. Also, water does not come out of the dispenser. The rest of the...
YEAH YOU HAVE ABAD DISPENSER CONTROL BOARD AND OR SOLENOID IS SHORTED IN THE DISPENSER... not to bad to change remove the outer cover and you should be able to see up there and how it operates... there is a control which you already know the display that feed power and also a actuator that controls the door flap. it is going to be one on the two...
good luck and repost if you have anymore questions ... please vote...
Jan 03, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker on GE TFX25ZRYD quit working
make sure the water line is not kinked when the refrigerator was pushed back.
Jun 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
