Question about Yamaha RAV-300 Remote Control
RAV311 WJ40930 US how to program the TV on the remote
BenguinRAV311 WJ40930 US
(1)To program the remote to control a TV, press and hold [TV] for at least5 seconds. To program the remote to control any other device, press andhold [AV] and the desired input button, (i.e. Press and hold [AV] +(DVD) at the same time for 5 seconds for a DVD player.
(2) Enter the 4 digit code for the device
My problem is the following have followed the steps in the manual and on this web site and it still doesn't work ! :( I press DTV/CBL on the remote then press AV power and on the unit display HRT6030 i see "remoteSetup NG" and then that disapears after like 2 seconds not long enough to enter any code what so ever, Am I doing something wrong or is this yamaha remote or av, i have set numerous remotes until today and never had this issue, any help appreciated. TIA
  • palmarkus Feb 27, 2008
    I have exactly the same problem,help needed??
  • Anonymous Mar 02, 2008
    Power and standby not working. All other functions OK.
It does not prompt you to enter your code, simply hold the 2 buttons for a few seconds, then enter the code you have. If successful, it will read remotesetup OK. Hope this helps and if you have any codes for techics cd players, let me know!
Posted on Dec 20, 2009
To program it, you need to hold down the AV button and the DTV/CBL button for 5 seconds, then enter your 4 digit code. Once you've entered the code, test the remote by using the TV button.
Posted on May 26, 2009
Codes insignia tv
2897,2891,2889,2884. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 30, 2013 | Yamaha Rav311 Remote Control
RAV311 WJ40930 VOLUME CONTROL
Might be the fault to remote control, to respective buttons contacts [inside] it. You have to clean the remote control to make it work. If you wish to get more details about how to check, repair and clean a remote control, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 04, 2013 | Televison & Video
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Hi There I do have a Yamaha Remote Control Rav312 that no longer work. I am thinking about buying a new one but can't find anywhere. However I saw a Remote Control Rav311 which looks almost exactly the...
i better suggest that you buy a universal remote that supports Rav312 rather than buying a Rav311, coz sometyms there are instances that even they look exactly the same the programs of each buttons are different unless they have the same chipboard. So, to play safe go for a universal remote that supports Rav312. hope that it helps.
Feb 16, 2011 | Yamaha Audio Players & Recorders
How i can program my remote jensen jer 622
Try the following steps. 1. Turn on the tv 2. Press and hold the "tv" button. The light should turn on and stay on. 3. While holding the "tv" button down, press and hold the on/off button. The light should go off, but if you keep holding the buttons, it will turn back on. 4. When the light turns back on, release both keys. 5. Press and release the on/off button repeatedly (while pointing the remote at the tv) until the tv shuts off. 6. As soon as the tv turns off, stop pressing the on/off key and press "stop." This will save the code that controls your tv. 7. If you wish to program your remote to other devices (vcr, dvd, etc.), use the same process described above, except turn on the device you want to control and press the component button that corresponds to the device, rather than "tv." For example, if you want to program your remote to a vcr, you press the "vcr" button instead of the "tv" button, as in the instructions.
I hope this helps! Sincerely, Der Strom
Apr 14, 2010 | Jensen 143307 Remote Control
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
Codes and programing
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
Dec 22, 2009 | One For All URC-3021 Remote Control
How to program remote control urc-3021b00 please
Hope that helps.
Nov 15, 2009 | One For All URC-3021 Remote Control
How to program my rav 300 remote
Here's how I got mine to work. FIRST THING: Once it's programmed, you use the TV function keys at the bottom of the remote for Power On, channel changing, etc. The other keys on the remote don't operate the TV.
1) Press the "code set" button with a pen or straightened paper clip
2) Press the [A] key (next to "V-AUX")
3) Enter the code
Test it by pressing the Power key in the TV section on the remote (NOT the "Source" Power" key or Main power key at the top).
Jan 10, 2008 | Yamaha RAV-300 Remote Control
Need the RAV-300 Remote Control Setting Steps
RAV311 WJ40930 US
(1) To program the remote to control a TV, press and hold [TV] for at least 5 seconds. To program the remote to control any other device, press and hold [AV] and the desired input button, (i.e. Press and hold [AV] + (DVD) at the same time for 5 seconds for a DVD player.
Hope this helps.
Jan 08, 2008 | Yamaha RAV-300 Remote Control
Televison & Video Logo
3,419 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
