Question about Ricoh Aficio SP-C210SF Printer
Unable to print on new dell with windows 7. tried to load drivers off of disk but says incompatable with windows 7.
  • 10,865 Answers
Hello. You can download a driver that is compatable. Just google the brand and model name of the printer along with the words windows 7 driver. When you locate it, download and run. Regards, Joe
Posted on Feb 02, 2010
What can I do to reboot new hard drive
So a new drive will of course, have nothing on it at all. Lets just say you are installing windows 7. With the windows 7 disk in the optic drive as the power is turned on - check for boot options at start up or hit your Del key to get in to the bios. Search bios for boot priorities - Set optical CD/DVD drive as primary (first boot) Make sure you can boot to the windows disk.. Once it sees the disk in the drive - follow the directions and the disk with start the install process. AFTER your windows os has loaded, you may need to find orphan drivers that did not load with the windows disk. You'll have to search Dell.com for proper drivers. Oh, huge - If the computer is running SATA 1 - Pentium 4 to first generation Core 2. You may need to hit your F4 key to add other drivers at the very beginning of the windows install.
The drivers most the time, show as a raid driver, but this is needed or your system will never install - The Hard drive will never be found.
Hope this helps.
Have a great night..
Dec 19, 2014 | Dell Recertified - GX620/2.8/2G/160G/W7P...
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
Can't install printer on my laptop, Dell Inspiron 5030 using Windows 7.
Try installing the printer driver that corresponds with your operating system.You can download the driver here but make sure you specify your operating system type[windows 7].
Hope this helps.Thanks!
Please rate this answer.
Oct 19, 2011 | HP Photosmart C5280 Printer
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
I have a Dell 962 all in one printer and a Windows 7 based pc , I can print and copy but it wont allow me to scan. do anyone have a solution for me to try?
most of these printers have a print center to load with drivers,check and see if you loaded center if you dont have disk go to dell site and download drivers free.
Jan 11, 2011 | Dell 966 All-In-One InkJet Printer
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I would like to install my Officejet J3680 onto my new Windows 7 laptop and am unable to do so due to them being incompatible. How do I fix this?
The Software disk you are using to install may not have Win 7 Drivers for your PC.
Try to download the Drivers from Web ( 32 bit or 64 Bit ) and install.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3441026&lc=en&cc=us&dlc=en&lang=en&cc=us
Jun 22, 2010 | HP J3680 Officejet All In One Printer
Need Windows 7 Update
You can get a update for windows 7 on www.windowsupdate.com as for your printer try to un install the driver than re install you may also look to see if it is compatable with windows 7? check the owners guide on your printer, I don't think it is but not 100% positive about that,check owners instructions and guide
Apr 11, 2010 | Dell 966 All-In-One InkJet Printer
New laptop Vista
I am guessing that the instal disk that you used was not for VISTA? Download and instal the VISTA driver from the DELL websie for you model printer, below:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=photo+720&rpp=12&p=1&subcat=dyd&rf=all&nk=f&sort=K&nf=19019~7~161365&navla=19019~7~161365&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav
Jan 13, 2009 | Dell Inkjet 720 Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Ricoh Aficio SP-C210SF Printer Logo
177 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
