Question about OKI B2540 MFP Printer
Oki b2540mfp fuser error. Is there a reset in maintenance mode or do we need a new fuser unit?
Replace main board...thats what i had to do...
Posted on Apr 15, 2010
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
How to reset he 980 fatal error on a oki 610 laser printer
The OKI 980 Fatal error is a Fuser that needs to be replaced. Replace the fuser
that being said you can replace the fuse on the fuser unit or you can do the option below that I DO NOT RECOMMEND
separate the fuser unit in half
Unravel and loosen the wires at the connector at the bottom of the fuser close to the edge so you can pull that connector out a few inches so you can get a couple of wires in there.
Insert a wire into each of the two holes on the back of that connector. 2 and 3 have wires going in, 4 and 5 don't which is the fuse. After you get the wires in the 2 holes. Make sure the wires are long enough to hang out the case. put the case back together and put the fuser in. connect the two wires together and power up the machine. As soon as you here the first motor, which is about 5 seconds into the startup, pull the wires apart. This will make the machine think that the fuser has been broken and reset the fuser life.
You can also purchase new fuse units from ebay etc and replace the fuse unit.
Sep 01, 2014 | OKI Office Equipment & Supplies
How to reset fuser life error
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
Jul 23, 2014 | OKI C Office Equipment & Supplies
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Need to clear the error code "replace Fuser" Fuser is new and so is the paper tray cannot seem to get the darned thing to clear
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Oct 07, 2008 | OKI B4400 Digital Mono Printer - Black
OKI B2540 MFP Printer Logo
1,200 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
