Question about Toshiba TDP-S8 Multimedia Projector
The unit doesn't come on, no light and seens no power either
  • 148 Answers
The problem is the powerboard, it tries to charge the components up with electric, then somewere it hits a faulty component (capacitor) and shuts itself down (standby mode/blinking etc)...You coulv'e heard a small "pop" when this first happenend...Maybe the unit started to take longer and longer to "warm up"....Maybe it shuts down after a while, either way the end result (as the cause) is usually the same...the machine fails, you research for hours, you give up and pay a repair man to order a $200/$300 part, just to charge you another$100 orso to install it (20 minutes for a average joe/4 minutes for a pro)...try this procedure on your projector (I wrote it for a lcd/plasma tv repair, so just replace the words "monitor/tv" with "projector" and the diagnoses, diss/assembly and repair stays the same...Here it goes;...........................................
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight projector technician!
If this helped (or not helped) you, please rate, thank you!
Posted on Feb 02, 2010
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
FUEL GAUGE DOESN.T REGISTER
most of the time with gm i have seen a bad sending unit inside the tank i have seen on this body style van where the wires go threw the floor the connectors corrode
Jul 08, 2012 | 2000 Pontiac Montana
Power light flashes put unit doesn't power on
Laptop is having a power problem. Problem is either from the Adapter or battery (optional). Or the power part on the mother board has a shot.
Jan 26, 2012 | Gateway M465-E Notebook
My machine will not turn on
Greetings. The schiller AT2 is battery powered. It will power on when plugged in however even with a dead battery, but if the battery is REALLY bad, we have seen it load the power supply preventing power up. On the top of you unit there is a small green "AC" indicator that should be illuminated when the at2 is plugged in. If it doesn't, your power cord might be bad, try a new one. If that doesn't fix your problem I would try at least to replace the battery. The battery requires dis assembly to replace, and there are three cable attaching the top case to the PC board. If you pull it apart to far without detaching the cables, you will do expensive damage. Also the removal of top case exposes high voltage, so this should never be undertaken a. with the unit plugged into a wall outlet, or b. By an unskilled individual. I would recommend that you find a local bio-medical contractor, or other service company, and have the battery changed. If your chosen contractor replaces the battery and the problem remains, your main board likely needs replacement, again by a qualified individual. Be warned however this in a very expensive part. There are several other possible problems, but very few that are operator serviceable. Best of luck!
Nov 17, 2011 | Schiller Cardiovit At 2 Light Ecg Machine
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
The yellow light telling you the last gallon of fuel doesn`t light up I already change the little bulb, but still doesn´t work. What can i do?
never seen one go out,must be driving on empty alot,check fuses,if you have power to the light then your instrument cluster could be bad.
TIM..........
Oct 22, 2010 | 1995 Honda Accord
Power signal light is flickering
If the unit is still working, and the power light is flickering, don't worry about it. I've seen this very often where the small, rectangular power light flickers and there is absolutely nothing wrong with the unit. It's just the light going bad. It will probably, eventually go out all together. Again, as long as it's working and keeping temp. don't worry.
Dec 30, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Info
Is the power light on? If not, recicle the monitor. If it is on, then maybe the back lighting is the culprit.
I have a similar problem, and the repair is more expendive than buying a new one.
Sep 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
I have seen it like this before!!!
Do you have dual os please specify, if yes, there may be a problem with the bootsector of hdd. to solve this further ask me thx
Aug 16, 2007 | Acer Aspire 3000 Notebook
Toshiba TDP-S8 Multimedia Projector Logo
1,145 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
