Question about Ovens
The oven wont turn on it has an error coer of F3
  • 619 Answers
This code is usually oven sensor but alot of tomes I have found bad solder joint where the sensor harness plugs onto the main board. This can be resoldered to save costly exchange of the board. The oven sensor should ohm at 1000 ohms with a meter with a 10k setting.
Posted on Feb 02, 2010
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Frigidaire model FEF352CATB has a F3 error code
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 14, 2012 | Frigidaire Ovens
The oven wont turn on when you push the on button it gives an error code of F3
Usually F3 is oven sensor open or shorted to ground. You can try replacing, but have found in past that The connection on the board where the sensor plugs into has come lose enough to lose connection. Is able to be resokdered if you know how. This would keep from having to replace the whole board. Hope this helps. The sensor should ohm at 1100 ohms on a 10k setting on the meter.
Feb 02, 2010 | Ovens
Onen display shows f3
The F3 error code relates to the oven temperature sensor and usually means this has failed and needs to be replaced.
It is a reasonably straightforward job, details of which you can find here; www.fixitnow.com/2003/02/appliance-tip-of-the-day-oven-temperature.htm
Jan 18, 2010 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
