Question about Apple iPhone 3G
I have a water damaged 3g 8gb motherboard with a pin broken off the LCD connector on it, can this be replaced and where do I get this fixed?
  • 109 Answers
We repair water damaged iphones but if a pin is fused to the board chances are it is too far gone.
Posted on Feb 03, 2010
Cheapest way to fix broken screen for a MOTO G?
Google "replacement screens for cell phones" . You can get a new screen way cheaper than a repair shop. You tube may have a video on how to replace it as well.
Jun 20, 2015 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Iphone wont charge
follow this steps and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Jul 31, 2013 | Apple iPhone 3G
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 28, 2010 | Acer Computers & Internet
I got my apple iphone 8gb wet in rain.now its screen has turned black and stopped charging. now i am unable to use it
Your phone is water damaged, try putting it in a bowl of rice , which should help to absorb the excess moisture. Other than that maybe send to to an iPhone repair shop.
Jan 10, 2010 | Apple For iPhone 4/8GB LCD Screen...
Dead apple iPhone 8GB
Take it to the shop find out the problem.
possible problems
Water Damaged
Battery Dead
Software damage
possible solutions
not much for water damage
press the sleep/awake button and home button at the same time
restore the settings,
Aug 14, 2009 | Apple iPhone Smartphone
Broken screen
Hey how are you!!!
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
screen-not-working-3.jpg Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
screen-not-working-4.jpg The video cable has to be seated properly, all the way down.
screen-not-working-5.jpg Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
screen-not-working-6.jpg OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Good luck
ICmanServer
Aug 01, 2009 | Acer Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Apple iPhone 3G Logo
383 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
