Question about Dishwashers
Last 2 washes we noticed there's water at bottom of the tub and we have to scoop it out with small pot. Any suggestions? Is it clogged somewhere?
    Problem Solver:
  • 10 Answers
Perhaps your drain hose is kinked, either under the machine (remove the lower panel to view) or kinked/clogged where is connnects to your sink drain. If you have a drain button and pressing it does not turn on the pump you have other problems.
If this does not help include your make and model to improve chances for a better response. Good luck!
Posted on Feb 04, 2010
Flashing but nothing happening
A-- If you hear the water filling for 3 minutes before the lights flash, 2 things could be happening:
a.1) water never reached the proper fill/run level so the computer prevents the heater from starting and alerts the user. There should be a code list in the troubleshooting section of the user manual describing the blinking lights and what they mean.
Solution- verify by sound if water flows at the same rate as the sink tap, if not then shut off the water and check the inside the connection hose for debris against the screen inside the hose end or insid ethe machine end where there is a intake valve. The debris keeps sediment out so it works but there's no auto cleaner for the screen.
a.2) Otherwise the heater itself is faulty meaning it does not conduct an electrical path or maybe overheating (could be dry) and the computer senses the wrong temperature either too high or too low.
Solution- A service call to determine the reason why; heater continuity, water valve, heater relay, hi-temp fuse, etc.
B-- Now, if you do NOT hear water filling for those first 3 minutes, 3 things could be happening;
b.1) House water supply is turned off.
b.2) hose is clogged (see solution a.1 above)
b.3) Drain pump inside dishwasher was clogged during the last run and old water didn't drain out (maybe some water is evident in the tub bottom).
Solution- Most dishwashers start each wash cycle with 30 second drain pump running to make sure the tub is completely emptied so the next fill cycle can't overfill. This ensures that if the user finds a 3 liter pot that flipped over during the last wash and if they dump that full pot of water into the unit to make it lighter, that the water will get drained before the new water enters the tub.
If the drain pump is clogged reset the power and restart the wash cycle. Note how much water is in the tub and see if it goes down any during those 30 seconds by opening the door afterwards. Find the clog either a bone or plastic bag or some small pice of a childs toy is stuck in the drain pump or the other end is clogged maybe by grease or bones if you have a sink disposal unit. The things they grind up drop into the drain 1" inch above the hole for the dishwasher drain tube.
NOTE: There is also an overfill [float] switch if the water inlet valve gets stuck open and the water keeps filling, the drain pump is switched on until someone comes and shuts off the water supply. When the tub drains the float drops and the drainpump stops. This will also make lights blink so check the user manual for codes or call the factory service reps [1-877-337-3639].
Either way, there should be instructions to reset the machine for restart. If it doesn't reset you need someone to fix the control that tripped the unit, maybe a safety fuse or a broken piece of the puzzle.
Aug 17, 2013 | Haier DW12-PFE2 24 in. Dishwasher
Error e1. washing machine will not drain. The tub is full and between the wash and rinse.
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Aug 10, 2009 | Haier HLP21E Top Load Washer
Water standing still in tub after load is done!
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 04, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
WASHER WONT DRAIN
Take off the lower panel ( 2 screws on bottom) pullout and down to remove. Make sure unit is unplugged pump is on the right hand side one hose coming from bottom of tub and the other goes out the back to the drain. Take off the hose from the bottom of the tub and be ready to catch alll the water in the tub suggest you use shop vac and remove all water first. look in the impellar in pump should be a clog right there then put everything back the way you toook it off and be careful to get the hose back on the way you took it off there is a slot in the hose and a tab on the pump for alignment.
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Dishes not being washed
Check your wash arms are they clogged. If you have too much trash in the machine you may have clogged your wash arms. OR you may have a screen in the bottom of the tub that is clogged with trash not allowing your pump to pum the water adequately. The last possibility, is your pump impala is damaged or worn out and not pumping water. The wash arms and screen you can do. Call a repair man if that doesn't take care of the problem
May 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Vintage Revere Ware Copper Clad 8 Cup Drip Coffee Pot
Barbara,
Coffee grounds go in the top. (i use a filter paper also.) Install baffle with stem up. Assemble top to empty bottom section. pour boiling water into top. I use 4 cups water, 2 scoops chickory coffee. Let water trickle down into bottom. I put mine back through 3 times, black as tar. That is the advantage of this machine. I will never use another.........
Mar 11, 2008 | Kitchen Appliances - Others
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
10 yr old Kenmore 70 series top load washer
Sounds like either the water level sensor (called a pressure switch ) is malfunctioning or there is a mechanical problem with the switch meaning that the tube that goes from the switch is
a) Kinked or crushed
b) has a small hole
c) Has become clogged
d) Air dome (where tube goes to on outer tub) is clogged
Jan 19, 2008 | Washing Machines
LSR8233JQ washer water drips into tub from fill port
Yes the fill valve has been damaged by the silt. If you remove the hoses from the valve you will probably notice that there is either one or both steel screens missing from valve body. You cant remove the screens if they get clogged.
Jan 19, 2008 | Whirlpool LSR8233J
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
