Question about Sony Cyber-shot DSC-W55 Digital Camera
Ricoh webcam i can't get my Webcam to work on MSN anymore. It used to work but i start a Video conversation and it says my camera is in use on another program. ???? ricoh 1.3MP
  • solsau May 17, 2008
    I've had the same problem that is describe here. My Ricoh camera was functioning with msn and other softwares, but now it doesn't runs anymore. I've uninstalled drivers and installed them again but it continuous not working.
    My camera is incorporated in my hp pavillion tx 1000.
  • schlott Jul 02, 2008
    i have a same problem in a vaio vgn-fz 340n, the driver installed no recognized the camera ricoh 1.3, a like a any support or help in this case.
    Thanks
Yes download call youcam on hp webside it will work
Posted on Aug 15, 2008
I have a same problem in a vaio vgn-fz 340n, the driver installed no recognized the camera ricoh 1.3, a like a any support or help in this case.
Thanks
Posted on Jul 02, 2008
Acer crystaleye webcam
You need to configure your MSN Messenger to use your webcam by going to options and select video or webcam preferrence.
Jun 09, 2010 | Acer Aspire One PC Notebook
Not working on msn
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Apr 18, 2010 | Microsoft LifeCam VX-1000 Personal Web...
My logitech web cam does not work with Windows Live Messenger. after I started a video conversation session, I can see the videos of both ends (mine and my conversation partners 's), but he can not see...
Check your set-up
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Jan 04, 2010 | Logitech Webcam
My dells webcam wont work on msn,
If the web cam is working normally with other web cam applications but MSN then it's required to configure MSN to use the web cam. Please follow the steps given below to configure MSN to use the web cam.
(i) Please ensure that the web cam is turned ON.
(ii) Then, double click the MSN icon and log on.
(iii) Click on the Tools menu, then click on the audio/video tuning wizard. Then, click Next to start the wizard.
(iv) On the first wizard page, under Camera, click the web cam then click Next.
Performing all the above steps will configure MSN to use with the web cam.
In order to start a video conversation, follow the steps given below after signing in MSN:
(a) Click Action, then point to audio/video.
(b) Then, click start a video conversation.
(c) Select a contact from "My contacts" page then OK.
Sep 01, 2009 | Dell Inspiron 1501 Notebook
Ok everytime I try to start a webcam conversation on msn, it refuses to run, the message that it gives is as follows. We couldn't start your camera device. Please check that your camera is not currently in...
You need to reinstall the driver again. 1. Disconnect camera from USB port 2. Remove driver by: right click on 'My Computer', 'manage', 'device manager', right click on the VX-1000, 'uninstall'.... 3. Reboot/restart 4. Ignore popup 'do you want to blah blah..' 5. Install driver from driver disk or file 6. reboot/restart 7. Connect camera 8. Test using MSN audio/video tuning wizard Guaranteed fix!
Jun 06, 2009 | Microsoft LifeCam VX-1000 Webcam
Audio doesn't work properly
yep.. try using the audio and video tuning options within MSN.. you may not have the Camera as the default audio device..
May 16, 2009 | Microsoft LifeCam VX-1000 Webcam
Logitech webcam works but it doesn't work when i go in msn
first of, install the driver camed with your webcam to your computer to be able to recognize it and to be use for internet messaging or in msn. after the installation, reboot the computer and it should work for your internet conversation after that. hope that helps
thank you for using fixya
CHARCOIS
Nov 02, 2008 | Logitech QuickCam Express Web Camera
HP WEBCAM DOESN'T WORK WITH INSTANT MESSENGER
Are you using Flash Player on MSN? This sounds like you need to turn on access from the flash player setting menu. This sounds like another issue with the latest update of flash player. Also, you might try 'unchecking' the box for 'use hardware acceleration' in the flash player settings.
Apr 26, 2008 | HP Pavilion dv6000z Notebook
Acer Crystal Eye Webcam and MSN Messenger
hi,the acer crystal eye has issues with mcafee site adviser either delete it as i did or configure it.search mcafeemessenger click on microsoft live messenger 2009 (v140) conference link to the appr opiate page hope this is helpful.
Mar 19, 2008 | Acer Aspire 4315 Notebook
Sony Cyber-shot  DSC-W55 Digital Camera Logo
133 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
