Question about Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
Is it hard to install a remote start /alarm in a 2003 mazda mpv autopage c3- rs730
    New Friend:
  • 71 Answers
Make sure you get one to fit that year make and modle and yes it takes some mechanical know how.
Posted on Feb 02, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I loss my sim I'd number for my C3 - RS - 665 autopage alarm
If the alarm brain does not have a sticker with the ID number than you will have to pull the SIM card out. The SIM card will have the ID number imprinted on it.
Sep 04, 2012 | C3RS6652W
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
I just got my autopager rs730 installed a couple days ago, later on that day when i picked it up, the remote start wont work, i think i maybe turned something off, but it comes up with either out of range,...
You just had this installed... you picked it up and later that day it didn't work? I recommend that you return to the location that you had it installed and have it checked out.
Jun 20, 2011 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I am having problems with my alarm/ remote start system. My remote is not comunicating with my truck
I am the senior tech support person for Autopage. You will need to do 2 things. First you need to unplug the antenna and let it sit for a few seconds. Then plug it back in. Attempt to hit unlock on the remote. Next step is to completely reprogram the remotes. This can be done by turn the ignition ON 3 times, and then leaving it in the ON position. (ON/OFF, ON/OFF, ON) then press the RED VALET switch 2 times, and holding on the second push (push valet and release, then push valet and hold). Once the siren lets out a long chirp, then release the valet switch, and program the remote by hitting the LOCK button on the remote itself. Program all your remotes you have, until you have programed 4 remote controls into it. It will cancel any prior remote codes. If you still cannot get this correct, you can call my technical support office at 1-800-945-2527 x600. And i will walk you through it.
Aug 23, 2010 | C3 RS900LCD 900MHz SixChannel Alarm System...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
I have the autopage rs730 alarm with the c3 ups module? My problem is that I cent control my car from either laptop or cell phone? I can locate it with no problem but cannot control it from either device?
You will need to verify the DATA cable is plugged into PORT B on the main unit. This is essential for correct communication between the 730 and the C3 unit.
Jun 28, 2010 | RS730LCD REMOTE START 2WAY SECURITY SYSTEM
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
277 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
