Question about Panasonic Lands Phones
I have a panasonic vb-9 series plus and the dnd/cf int button is in green colour. how i off it as i am unable to receive any intercome calls. thanks
SOURCE: I have a panasonic hac
Pick up the handset or press "on/off" key
Dial "73"
Posted on Feb 20, 2009
SOURCE: DO NOT DISTURB (DND)
Press FNC 69 FNC
Posted on Apr 08, 2008
Centernet
  • 38 Answers
SOURCE: DND button will not turn off
Depending on how your system is programmed, you might be able to turn it off by pressing it. Otherwise, you might have to press it and dial a code number, which also can vary from one installation to another, but I would try "0"
Otherwise, it can be programatically corrected by your installer if the system got "stuck" or something.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
  • 149 Answers
SOURCE: How do you remove the DND feature on phone model NEC Dterm Series III?
Feature 69 feature.
Posted on Nov 13, 2008
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic kx-t7030 FWD/DND button
Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
Carl
Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
Panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
May 07, 2009 | Panasonic KX-T7633 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic vb-42211 phone won't ring. How do I
1) Press PROG, follow by programming no. 50 or FWD/DND button.
2) Press ENTER or STORE, follow by selection no. 0=OFF FWD/DND, 1=ON FWD/DND.
3) Press ENTER or STORE to save the setting.
4) Press EXIT or PROG to quit setting mode.
YBC (/\)
Feb 18, 2009 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
443 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
