Question about LG WM-1832C Front Load Washer
I have roughly the same problem. The machine starts but when it comes to draining the machine just humms. If I pick the front end up and drop it with a hard bang it starts the pump. Pump or Sensor?
    President:
  • 842 Answers
Pump. Probably got something stuck in or near it. Get underneath, check out filters and squeeze the pipes on the way toward the pump. You'll probably find a sock in there :-)
Posted on Feb 02, 2010
The noise thats coming from the machine its a like rubbing thumping noise. comes on when i start the washing cycle and spinning cycle.
noise from tumbler humm
which brand and make of front loader
then someone can answer the question better
Jun 14, 2016 | Washing Machines
Roaring sound in front end, sounds like driving onvery rough road.
A roar comes from hub bearings pick up the front with a jack n shake the tire back n forth if it has play your bearing is bad
Sep 23, 2015 | Cars & Trucks
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
Washer will not spin, filled up with water and stopped. When turn back on, it just humms then stops
The most likely cause is a blocked pipe or drain motor. This could be caused by an obstruction, such as a screw, hair clip or coin jamming the impellor inside the pump. Firstly, try to manually empty the machine of water. Take the drain pipe and lower it to a position below the machine itself. This should cause a syphoning action. Uou may have to give the end of the pipe an initial **** to start the flow. Remember to give the pipe a clean first with hot water and don't swallow any of the water.
Jul 31, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Wont drain
If something smells it is overheating and heading towards total breakdown.....even catching fire!
. Stop using the machine and have it checked by a local qualified techo for that brand.
Sep 20, 2009 | Bosch WFMC 3200 Front Load Washer
The washing machine starts, then stops, then starts, then stops
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 09, 2009 | Kenmore Washing Machines
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
Mar 18, 2009 | Washing Machines
Whirlpool duet washer wont run
sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer not spinning or draining
Same problem.  Water wouldn't drain, no trouble codes, door wouldn't unlock.  When the Rinse and Spin cycle or Drain cycle was selected all I got was a growling humm from the pump.  Clued in by the above postings I pulled the washer away from the wall, tipped it back so it leaned against the wall with the bottom fully exposed and removed the plastic panel covering the bottom (underneath - 4 screws) of the machine.  The small pump was just where these postings said it would be, top right of the bottom opening. Disconnect the two drain hoses from the pump. Mine were connected with hose clamps that I removed with just my thumb and fore-finger.  I had two quarters AND a nickel lodged inside the pump and was able to coax them out without removing the pump. Replaced the hoses and bottom panel, tipped upright and I was back in business - didn't even have to unplug (Its never a bad idea to do so) or disconnect the water hoses.
  • Total time spent: including searching for these posts and random dead-end trouble shooting - 1.5 hours.
  • Tools: 1 Phillips screwdriver.
Jul 16, 2008 | Maytag MAH6500 Neptune Front Loading...
Spin Cycle quit and just hums
You may have a drain error problem.  The unit will not go into spin if the water cannot be extracted properly.  Check your filter screen to make sure that it is clear.
Nov 16, 2007 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
102 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
