Question about Toshiba 62HM95 62" DLP HDTV
HOW TO CHECK BALLAST LAMP FOR 62HM95 - Toshiba 62HM95 62" DLP HDTV
  • Toshiba Master
  • 5,138 Answers
Ballast Board Powers Lamp, the 2 plugs on Lamp connect into Ballast
board just follow the wires from where lamp plugs into.
Does Ballast have a ark coming from a componet on board and does the main capacitor Look Vented or puffed up on top?
Remove Lamp turn TV on see if Ballast has a ark coming from a Big Whit/blue writing on it spark cap?
Posted on Feb 19, 2010
  • 3 more comments
  • ladywinn
    ladywinn Feb 19, 2010
    If ballast has ark coming from it,then that board is good ! Then if set does not come on it will be Defective Lamp Fan or Lamp.
  • MACangel44 Nov 16, 2010
    My tv is a 62hm95 toshiba and i have a code that blinks in the front, the code is: three red and one green? what does that mean and how could i fix it? thank you.. i changed out the bulb but still no picture, they tell me it might be the ballast but do not know where its located?
  • ladywinn
    ladywinn Nov 16, 2010
    Ballast Board connects to the Lamp. Lamp connects to the Ballast board.
    Ballast board has 2 wires coming from it that goes to the Lamp.
  • VAPowells Nov 16, 2010
    @MACangel44 According to my owners manual, it sounds like it might be a "Lamp door is not seated properly" Book describes the code as " Green Light Blinks continuously at 3-second intervals. red blinks continuously at .5 second intervals" REF: page 99 of original manual for 46,52,62HM95's There must be a sensor at the lamp door, may have gone bad and giving false open or may need to reset the door. Hope that helps.
  • kim coons
    kim coons Oct 13, 2013
    how do you reset the door?
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
I have the toshiba 62"
The tv projection Lamp shutdown 3-4 mins,than u hear alot of clicking noises sound too?Yes,than the board that call the Ballast board it is dead too.The Ballast board only job are to help to ignite the projection Lamp only.
Jun 07, 2011 | Toshiba 62HM95 62" DLP HDTV
We put in a new lamp probably a month or so ago. I'm not sure how to describe it except that some colors are now "brighter" than they should be and flicker while watching TV. This seems to have...
U replacing the tv with a new lamp with the original Toshiba reconmended lamp?Generic lamp might have this problems for some tv and don't last as long as the original name brand lamp.Also the board that call the Ballast board might be dying too.The Ballast board only job it is to ignite the tv projection lamp and kept it being lit.
Apr 07, 2011 | Toshiba 62HM95 62" DLP HDTV
The lights indicated that I needed to replace my lamp. After doing so, the TV still doesn't have picture. What do I have to do to get it to work?
It is possible that the Ballast is not turning on the lamp. In past years it had been difficult to get the Ballast separate from the Optical Block but they seemed have them available. In order to replace it you will need to remove the Optical Block which is in the center. The ballast assembly is mounted on the right side of the OpticaL Block. Once the Optical Block assembly is removed, it is not difficult to replace. To order a Ballast, call 1800-631-3811. You will need the model number.
I hope this helps,
Skyassoc
Dec 10, 2010 | Toshiba 62HM95 62" DLP HDTV
I own a Toshiba 62HM95. It's about 5 years old. It was turning off and on, but now nothing. Any idea what it could be?
I think the problem is coming form your lamp if you have not replaced it before but if you just recently replaced it then I would have to say you have a bad ballast here is a store that carries your lamp
http://www.discount-merchant.com/SearchResults.asp?Search=62HM95
Sep 15, 2010 | Toshiba 62HM95 62" HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Trying to find a ballister circut for a toshiba 62hm95 and is it something that i can replace myself
The Ballast is the correct wording.IT has four
screws and plugs into the lamp.very easy to change.
Sep 04, 2009 | Toshiba 62HM95 62" DLP HDTV
Toshiba 62HM95 62" DLP HDTV Logo
2,261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
