Question about HP Combo Case HP PAVILION Speakers, Mouse, HP Keyboard, Floppy (B09110)
My sesk top HP speakers are not working after I moved. speakers are built in computer
    Problem Solver:
  • 5 Answers
Are all connections inside and out secure? something may have gotten jarred loose. also check the settings for the speakers to make sure they have not been muted.
Posted on Apr 28, 2010
Just moved & set up my computer with HP w2338h monitor with built-in speakers, it does not play sound. I've restored factory settings, checked volume & mute, turned off/on, double checked all...
Try the following:
  • Right click the speaker icon in your icon tray > click playback devices, see if you can see your monitor there as an option, and if so, right click it and click "Set as default device"
Hopefully that helps!
Mar 15, 2011 | HP W2338H Monitor
Soundboxen do not work how can i find the drivers for it and how to installed it
No driver is needed for the built-in speakers to work. The built-in powered speakers work the same as a desk top powered speakers system.
You just need to ifind out if it is the amplifiers in side the monitor are bad or it is the sound card problem in the PC.
Feed the monitor with the sound source such as the MP3 player to see if you can get any sound from your monitor.
If it does not work then the problem is inside the monitor, but to have it repaired will be to expensive, you will be better off spending the repair money on a good set of powered desk top speakers system instead.
Please leave rating if it helps.
Jan 05, 2011 | HP Pavilion F1523 15" LCD Monitor
They dont work
Please re-install the sound drivers the would start working.
Jun 09, 2010 | HP (198710-001) Computer Speakers
Built in speaker does not work but headset is work hp pavilion dv6000. thank you
The speaker of your computer has a problem not the sound card device because when you're using headset its work. Try to use the external speaker when they are functioning, automatically you need to replace your built-in speaker to fix that problem.
May 30, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Can I use the my old HP speakers with my new HP? The old speakers have a peach, not green, material around the jack. The speakers that are built in with the monitor are working, but I think the old...
If the speakers are detachable from the monitor then try to put it in the jack where you usually put your speakers if you hear any sound it should work .the color coding is usually green but its not mandatory .
Mar 28, 2010 | HP Compaq Computer Speakers
The built-in speakers on my HP w2408h do not work. I checked the sound generating electronics in my HP computer with a headphone. That worked. I plugged in the sound patch cord to the headphone jack in the...
hello bill.. i have a 190 B and not getting sound... checked all sound generating electronics as well.. i wonder are the internal speakers 'gone'? in mine i.e...??
Oct 26, 2009 | HP Computers & Internet
Built in speakers dont work
These speakers probably don't have built-in amplifiers. Check the outputs from your computer to see if they should drive speakers directly or if it is a 'line' output that requires external amplification.
Sep 26, 2009 | HP vs17
I have an acer cpu connected to my hp monitor with built in speakers...but I have no sound?
That is a common problem. You need to purchase some new speakers from your local Radio Shack or computer store.Plug them into your cpu. Very cheap fix about $10. The mix and match connection of the HP and Acer never seems to work. The HP monitor will work with the Hp computers but not others.
Aug 15, 2009 | Acer (90.18612.36B) Computer Speakers
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
