Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
I always receive that I have an ip conflict with ohter network how to fix this?I've used d-link des-1016d.
  • 12,061 Answers
You need to set DHCP OFF on the PC, You see your router and your PC are BOTH set to DHCP. ONLY one can be DHCP and thats the Router. Turn it off will be OK.
Go to Control Panel, Administrative Tools, Component Serives, Services Local, and find DHCP Client in the list on the right. Double click on DHCP Client, and in the Properties window, General tab, in the middle you will see Startup type:. Set the type to Disabled. Hopefuly that should do it.
Posted on Feb 02, 2010
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to connect a lan
Just connect your router into port 1 and rest of your devices on the other ports. Its just plug and play. Im assuming your router is a DHCP server. If not, configure all your devices to static IP
Aug 01, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Driver
DEAR SIR
USE THE FOLLOWING SITE:
http://www.givemefile.net/drivers/hubs/d-link/des-1016de.html
click on file request
please fill the order form & follow the instructions
regards
murali
Aug 28, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES-1016D make the network failure
Is this a brand new switch? Or did it come from somewhere else? It might have an IP address assigned to it that is interfering with the rest of your network.
Try plugging in a laptop only to the switch and give the laptop a static IP, see if you can access the configuration of the switch.
Jun 22, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I want to know the ip config for this brand i have 15 computer
Hold down the rest switch on the back for 30 seconds. Go to start, run, type in cmd and hit enter. When the dos screen comes up type in ipconfig. This should give you the gateway address for the router. I think the standard ip for dlink is 192.168.0.1
May 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
831 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
