Can't upload mp3's onto camera
To transfer MP3 files to Digimax i6:
- Turn off camera
- Plug USB cable to PC and camera
- Turn on camera
- On your COMPUTER screen, it will tell you select USB: Printer or Computer
- Select Computer using the arrow buttons
- Press MENU/OK
- On your COMPUTER screen, a window will pop out like
Removable Disk and it will be telling you a lot of options
- Select "Open to View Files"
- You should be seeing the DCIM folder as you select that option
- Right click on the white space where DCIM is located
- Select "New" and then "Folder"
- Rename the folder as MP3
- Open your documents containing the MP3 files that you want to transfer
to your camera
- Make sure that the format is MP3
- Select the files that you would like to transfer
- Right click on one of those and select copy
- Now, go to the MP3 folder that you've just created
- Open the MP3 folder
- Right click on the white space of the MP3 folder
- Select PASTE
- All MP3 files will be copied to your camera
Note: It depends on the file size of your MP3 if it could still
be accomodated inside your memory card
To safely unplug your camera:
- Look for the green arrow icon on the lower right corner
of your computer
- Right click on that and select "Safely Remove Hardware"
- Just select your memory card in there that is pertaining
to your camera and select stop
- Once, you've seen the message "You could now safely remove the camera",
then you could now turn off your camera and unplug it so as to prevent any problems
On your camera:
- Turn it on
- Press the M button
- Scroll to the right until you see MODE menu tab
- Use the down button to select Still/Movie/PMP
- Press MENU button (all will disappear)
Now,
- Select Resume
- Make sure to be on MP3 mode
- Select the desired files and those will play
If it still does not work, call the Manufacturer.
