Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have a Sears Opener 76LE that has operated without trouble for over 25 years. Yesterday, I tried to open door and as soon as unit was under load, went into the close mode, then tried to open, then closed. Repeated this cycle until I unplugged unit and disengaged door. The motor, chain, belt, pulley and door all appear to be in good working order. I assume this is a control problem. Is this fixable and are parts available?
    President:
  • 3,197 Answers
If your opener is truly 25 years old there are not going to be any parts available. The model number you give is not the model number. It starts with 139. and probably has 6 numbers after the period or dash. Once you have it you can go to Sears parts and see if there are parts available.
Posted on Feb 02, 2010
Garage door opener (Sears 139.664700) has power but will not operate when button is pushed
Could also be the start capacitor in side the garage door opener box, check for electrolytic driping out for signs of a bad capacitor...
Jun 21, 2012 | Home Security
I have a Sears Crafstman Garage door wireless opener. Model 139.53615SR . The door hums but nothing happens. The chain doesn't move. The springs on the door broke last year and i replaced both of them....
My plastic gear stripped soon after a spring broke. I think the broken spring put a huge load on the opener that day and ruined the gear. Replacement wasn't too hard. It will be obvious when you remove the cover if the gear is stripped. Here are instructions:
http://tinyurl.com/gearfix
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi Don, I have a Sears model 76LE that has been working fine but now it won't turn off when it closes. the motor just keeps running until i smack the side of the unit and then it quits. it opens fine, but...
I would remove the cover and take a good look at the limit switch assembly. If you watch it you will understand how it is supposed to work. There could be a bad connection on the logic board. You can remove it and check it over.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My remote intermittenly opens/closes the garage door
You can find a free manual for your door opener at manualsonline .com You might want to look at how to program it and change the unit to a different frequency. You can sometimes get better response and eliminate interference. Also make sure your battery contacts in the remote are clean.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Where is the emergency release on Sears Craftsman Garage Door?
You can find exploded views and parts lists of the opener at SearsPartsDirect.com
I just checked.
Feb 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wring sensors
whites together under 2nd screw, grays together under 3rd screw. both indicator lights (normally LED's) on the eyes (1 each) must be lit in order to operate. this is the basic set-up...if you give me your model number from the opener, I should be able to find a owners/users manual for the unit
please take the time to give this solution a fix ya rating
Thanks for using Fix Ya
clarkco
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master garage door opener Model 1045-6 1/3 hp
Most residential garage door openers have a max. amount of cycles they can run per hour. Thus the difference between a residential opener which only needs to be opened a few times a day vs. a commercial opener which needs to open 10-20 times and hour. This could be your problem, you may be running too many cycles too soon. This would explain why it seems to work again after unplugging the power. You're resetting the unit. Hope this helps.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
523 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
