Question about Krups KB720 5 Speed Blender
Motor sounds like its running, but the blades
I nicked the blade with a spatula while pushing some veggies and the motor stopped. Now, the motor sounds like its running, but the blades don't turn.
  • 421 Answers
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Posted on Feb 02, 2010
Rusting blade
Why don't you just clean it?
Very carefully use a soap pad, and then dry thoroughly. remember to dry thoroughly after every use, and wipe a little veggie oil on the blades with a paper towel.
Apr 07, 2014 | Bamix Mono Handheld Blender
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
The blade has become VERY tight and will hardly turn. When I turn on the blender the motor strains to get it turning, and when it does it makes a horrible sound. I've stopped using it because I don't...
put a socket or a wrench on the nut in the middle of the blades, and hold the other set with a set of pliers, and, as the original poster said, it is reverse threaded.
Mar 15, 2011 | Breville BBL550XL 5-Speed Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Motor runs but the blade does not spin
The shaft has probably siezed at the bottom near the blade. The seal can fail and let liquid inside the shaft and gunge it up.
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Then reassemble carefully
Dec 04, 2009 | Dynamic MD95 Handheld Blender
When trying to blend things like frozen fruit or frozen yogurt with the Vitamix, the blade stops moving, but the motor continues running. Even if there's only enough frozen yogurt to cover the blades, it...
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Jul 09, 2009 | Vitamix Blenders
Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Jul 03, 2009 | Blenders
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Krups KB720 5 Speed Blender Logo
377 people viewed this question
Top Krups Blenders Experts
Ross Keen
Kolbrun...
Jerry Kramer
Jerry Kramer
Are you a Krups Blender Expert? Answer questions, earn points and help others
